R56 My new Cooper Passenger Seat Wont Slide!?
Old Oct 13, 2012 | 06:44 PM
thejonathanpaul's Avatar
thejonathanpaul
Hey guys I purchased a new 2009 cooper and now I have realized the passenger seat will not slide! I have looked and all proper cables are connected and no coins stuck or on the track any insight this would be awesome!
Old Oct 13, 2012 | 08:17 PM
bluefox280's Avatar
bluefox280
You've pulled up on the bar assembly on the front of the seat, and it doesn't adjust forward or backward?
- Erik
Old Oct 14, 2012 | 07:18 AM
thejonathanpaul
That is correct it will not move forwards or backwards.
Old Oct 14, 2012 | 07:50 AM
bluefox280's Avatar
bluefox280
Purchased from a dealer or private party?
If dealer, return and have them futz with it.
If not, time to look under at the release linkage to see if it's connected, jammed or other.
- Erik
Old Oct 14, 2012 | 01:52 PM
thejonathanpaul
dealer but they are in miami and I am in Jacksonville!
Old Oct 14, 2012 | 03:21 PM
RJKimbell's Avatar
RJKimbell
Are using the lever rod in front of the seat only??!! Try using the Seatback Release on the upper back of the seat, this not only moves the seatback forward to allow passenger access but also should allow the entire seat to move forward as well. Also on the '08 model that I have, I've had this happen before, there is a small tab in the rear part of the track that will not allow the seat to move back and forth if it is in a certain position, I do not remember though what exactly you do to this lever to make it release the seat movement...sorry.
I do know that the seat is very particular as to what is done first to get it to move with the seatback moving as well, but using the Seatback Release will usually fix my issues.
Old Oct 14, 2012 | 04:03 PM
thejonathanpaul
Thanks man I will try tomorrow I am also a horizon blue!
Old May 14, 2013 | 02:55 PM
gribouille1210's Avatar
gribouille1210
hello guys, i am french and i have a mcs of 2009. I have a problem with passenger seat. My seat doesn't slide when i want to go at the rear seat. i have to use the bar in front of the seat. The cable under the seat is broken.
On realoem, i don't find reference of the cable. Everybody can help me to find reference or tell me if i can repair the cable.
Thanks a lot
[/IMG]
09R56
Nov 16, 2022 10:49 AM
minicoclub
Nov 11, 2015 07:25 AM
Zettinger
Aug 25, 2015 04:04 PM
minicoclub
Aug 25, 2015 09:07 AM
DWooderson
Aug 10, 2015 09:12 AM
