R56 Springs or Sway Bar?
Old Aug 26, 2012 | 09:02 AM
Jdblown03's Avatar
Jdblown03
I plan on doing both but which would I benefit more doing first, H&R sport springs or Alta 22mm rear sway bar and End lengths?
Old Aug 26, 2012 | 09:11 AM
RJKimbell's Avatar
RJKimbell
I just did both the Alta 22mm Rear Sway Bar and Endlinks on Molly about 2mo. ago, it is now set at the middle setting. So much smoother ride, way better handling...so glad I did this.
I'm doing the H&R Springs too, but will also be adding Koni Shocks, when I do. A few other must do's are in line ahead of the Springs and Shocks though.
Old Aug 26, 2012 | 09:19 AM
Jdblown03's Avatar
Jdblown03
So it sounds like the sway bar should be done before springs in your opinion. What are your other "must do's" before springs?
Old Aug 26, 2012 | 10:05 AM
Porthos's Avatar
Porthos
Get a Hsport bar instead and NM springs later on. Consider shocks when you do springs also.
Old Aug 26, 2012 | 10:42 AM
Jdblown03's Avatar
Jdblown03
Which H-sport, the completion,race or sport? Mostly hard street driving with an occasional track day.
Old Aug 26, 2012 | 11:19 AM
Porthos's Avatar
Porthos
This one
http://www.hotchkis.net/mini_cooper_race_rear_bar.html
Old Aug 26, 2012 | 11:44 AM
Jdblown03's Avatar
Jdblown03
Ok thanks. Is there any reason this one is better or just personal preference? Should I buy aftermarket end links also?
Old Aug 26, 2012 | 01:09 PM
Porthos's Avatar
Porthos
Personal preference. Sure why not it really isn't a big deal.
Old Aug 26, 2012 | 03:45 PM
Fizzyx's Avatar
Fizzyx
It really depends on what you want out of your car. Sway bars are mainly tuning devices to change the car's handling balance whereas springs (and shocks) are more the foundation of the car's handling.
IMO do springs and shocks first and see how the car handles. If it understeers too much for your liking get a beefier rear bar.
Old Aug 26, 2012 | 10:57 PM
RJKimbell's Avatar
RJKimbell
I've been hearing some noise from the rear brakes so today I ordered some Euro Ceramic Brake Pads from TireRack and tomorrow I'll be ordering Zimmerman Rotors and Sensors from Way Motor Works!!
I've relied on the advice of our very own PDX MINI certified MINI Mechanic for all of my mod questions, he hasn't steered me wrong yet, he installed the sway bar and endlinks for me at one of our Tech Days and has offered to do the brakes as well, I watched him install some on one of our Club Members 2005 MINI in what seemed like 5min. per wheel.
Old Aug 26, 2012 | 11:06 PM
RJKimbell's Avatar
RJKimbell
If you are going to "mod" your MINI why would you consider OEM; your not changing anything by doung that!!
Old Aug 27, 2012 | 06:53 AM
Jdblown03's Avatar
Jdblown03
I have read both that some people replace them and some say its not necessary that the OEM will hold up. If it wasnt a matter of money there is about 25 mods I would do all at the same time.
Old Aug 27, 2012 | 10:52 AM
RJKimbell's Avatar
RJKimbell
That's why I wait and do my "mods" at 6mo. intervals, I know what I want, I've researched beyond belief and I'm sure I'll have the $$ set aside!! The Brakes are a "have to" of course, so they really don't count as a Mod...albeit a nice one!!
Old Aug 27, 2012 | 11:54 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Go with the Hsport Comp rear sway bar, it is a much better quality part that won't squeak. Also you don't need rear end links unless you are trying to corner weight the car or put zero preload on the bar. When dealers tell you the stock end links are week, that is a BS sales pitch. In the last 10yrs I've only ever replaced one end link that broke that wasn't from somebody messing with it. Also the alta end links are very noisey and clunky.
Old Aug 27, 2012 | 12:33 PM
leaf_fan_1988's Avatar
leaf_fan_1988
Why does the hotchkis bar say:
"This bar is for competition use only and is not intended to be used on the street."
Sounds... good, but what about the people that drive their cars everyday?
Old Aug 27, 2012 | 01:12 PM
Porthos's Avatar
Porthos
Liability that is all. Because it can be too much for street driving if you are not an experienced driver.
rtk90
Aug 29, 2019 09:08 AM
ej
Nov 17, 2015 09:21 PM
dropnstylez
Oct 29, 2015 08:57 AM
Suspension Products
Sep 2, 2015 10:32 AM
