R56 Removing passenger side drive axle...
Old Mar 20, 2012 | 04:45 PM
thinkinmini's Avatar
thinkinmini
Is removing the passenger side drive axle from the transmission the same process as removing the driver side (pry bar, fulcrum, abrupt force)? I got the driver side off but there's this kind of plastic boot at the base of the passenger side drive axle where it meets the transmission and it confused me. I assume I just use a screwdriver to peel it back and do the same process as the driver side? Also, when you drop the transmission, did you need to disconnect the connectors on the turbo water pump below the oil filter canister, and remove the bolts on it as well? A how-to guide by lonestar mini club recommended it be done. On a side note, I think I will be purchasing the bentley repair manual. Dropped the subframe, placed car into service mode, removed exhaust etc etc but it would be nice to know a few other things.
Old Mar 20, 2012 | 04:46 PM
thinkinmini
I have the lsd if that means anything.
Kimolaoha
Jul 5, 2023 01:04 PM
boostedhaze
Jan 2, 2018 07:26 PM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
quality_sound
Aug 7, 2015 09:36 AM
