R56 Can someone show me to the cheapest source for a BSH Catch Can kit?
Old Jan 4, 2012 | 07:57 AM
Minifan07's Avatar
Minifan07
Thanks!
Old Jan 4, 2012 | 08:11 AM
Drobinson1692's Avatar
Drobinson1692
http://www.waymotorworks.com/bsh-oil-catch-can-r56.html
http://www.detroittuned.com/shop/?productID=494
one of those two. whichever has better shipping is the deciding factor. plus it's good to support one of these guys
Old Jan 4, 2012 | 08:34 AM
Minifan07's Avatar
Minifan07
I'm assuming this is a good mod being that it's been a heavily discussed topic around here. I'm new to the whole mini thing and it's my first DI engine. Thanks for the links.
Old Jan 4, 2012 | 09:03 AM
Braminator's Avatar
Braminator
For your engine it is a must.
Old Jan 5, 2012 | 05:21 AM
richardsperry's Avatar
richardsperry
And you probably need the dual port adapter to block off the passenger side CCV.
Old Jan 5, 2012 | 05:39 AM
Minifan07's Avatar
Minifan07
Where can I get that? Part no?
Old Jan 5, 2012 | 05:53 AM
drsimmons's Avatar
drsimmons
From your sig description Minifan07, I assume you have an 07 MCS. If so, Sku# r56bshcc for oil catch can and Sku# bshboosttap for boost tap from www.waymotorworks.com.
Normally has great prices or at least as good as anyone plus Way will service you well. He's very knowledgable and will answer any questions you have.
Old Jan 5, 2012 | 06:24 AM
Minifan07's Avatar
Minifan07
Ugh...thanks I just placed an order yesterday from WWM for the BSH catch can, oh well. I can still run the catch can for a few weeks and then install the boost tap right?
Old Jan 5, 2012 | 09:02 AM
drsimmons's Avatar
drsimmons
Did Way say that would be ok. If not, I'd wait and install both at the same time.
Old Jan 5, 2012 | 11:16 AM
Bigprfed22's Avatar
Bigprfed22
yes youll be fine, you just will not catch as much crud.
Old Jan 5, 2012 | 11:44 AM
artforge1's Avatar
artforge1
Thanks!
Empty coke can, high temp sealant and 2ft of rubber hose w/fittings.
Old Jan 5, 2012 | 11:48 AM
Bigprfed22's Avatar
Bigprfed22
Coke cans come baffled?
Old Jan 5, 2012 | 11:52 AM
artforge1's Avatar
artforge1
didn't say it was good
I may have spent too much time in Mississippi at this point....
Old Jan 5, 2012 | 12:19 PM
drsimmons's Avatar
drsimmons
Bigprfed22.....Got a question, probably stupid question but I'll ask you anyways.
What would happen (damage, etc.) if one forgot to check OCC and it fills up totally? Spill out to the turbo??
Haven't done it yet but just wondering.
Old Jan 5, 2012 | 12:26 PM
Bigprfed22's Avatar
Bigprfed22
Mayyyyybe under high G conditions, but realistically the can will be full so it will not catch any more, in that case the pcv gases will not condense thus it will be like it isnt there.
Old Jan 5, 2012 | 12:34 PM
drsimmons's Avatar
drsimmons
Thanks. Down here in lower Alabama due to the temp extremes, 38 one morning and 55 next I tend to get more water condensation so I've been checking every week. Check the oil and coolant at the same time.
Old Jan 5, 2012 | 01:03 PM
Bigprfed22's Avatar
Bigprfed22
Yeah any cold temps will make you think your getting more gunk but its just water condensation. I am running open pcv because i wanted to ensure no gunk got in anymore period... there goes my carbon footprint lol.
Old Jan 5, 2012 | 04:46 PM
Minifan07's Avatar
Minifan07
I lucked out, I was able to add the boost tap to my original order. Let the Mini Modding begin.....
Old Jan 8, 2012 | 10:27 AM
chimivee's Avatar
chimivee
So, what is the purpose of the boost tap? And why is it necessary in conjunction with the OCC?
Thanks.
Old Jan 8, 2012 | 10:56 AM
drsimmons's Avatar
drsimmons
Thanks.
I believe it stops any crud from flowing into the intake manifold (port side). I installed both boost tap and occ and love it. You won't believe the amount of crap you pull out of it.
The boost tap by the way has a plug in the end to stop flow as well as 2 plugs which can be removed for vacuum gauge addition. Don't know much about that part just know that both parts work. I use a 1 inch wide syringe with a 1/4 inch hose to pull out the crud from the dip stick holerather than draining from the lower hole on the catch can. Makes it alot faster and cleaner.
Aug 19, 2015 12:51 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
M7Speed
Aug 6, 2015 01:48 PM
