R56 R58
Old Oct 25, 2011 | 07:54 AM
  #26
oldsbear's Avatar
oldsbear
Originally Posted by MiniAJ
...if there is some type of coding that must be done that might be a problem.
You would need to buy a new toggle housing and toggle switch, plus reprogramming at the MINI dealership.
Old Oct 25, 2011 | 08:12 AM
  #27
klricks's Avatar
klricks
Ok thanks very informative. However now I have several questions.
@drexial can you please take a pic of the back of the fog so I can see if the wiring looks like mine.
@klricks if the wiring Is there can I just just buy the toggle switch and connect the wiring? Or if the wiring is not there can wire it then buy the toggle and connect it? Wiring is not an issue my dad is a electrical engineer. But if there is some type of coding that must be done that might be a problem.
The toggle handle is not really the switch rather it pivots and presses micro-switches on a circuit board. The circuit board is interfaced to the computer system and the 'footwell' controller module. The 'footwell' module controls allot of the other lighting as well. Even with the wiring and toggle present, nothing will happen unless the option is programmed at the dealer. It has been reported that some dealers can't or won't do it. I don't remember what the programming charge is maybe 1 or $200?
Adding the toggle can be done and there are threads on NAM about how to do it. The toggle handle is cheap but if you want a matching panel with fog light text then that is somewhat expensive but not required. A moderately difficult job to pull the dash apart to get the toggle in.
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
