R56 Red Brake Light on Dash
Old Jun 20, 2012 | 02:03 AM
  #26
luis's Avatar
luis
Originally Posted by hbr
You can "trick" your sensors.... cut the ends off and attach the two wires with a connector and tie strap them out of the way
I'll try that, thanks for the tip.
Old Jul 14, 2012 | 04:54 AM
  #27
lurch70's Avatar
lurch70
Originally Posted by lurch70
thanks so much ... followed it this morning and it worked!
ok, so the initial trick worked and then the light came back on about 150 miles later ... once ... reset it ... went off again ... and now back again.
i guess I do need brake pads though
what are good replacement pads that people have been using for everyday use? but not going the OEM route
will need front AND rears replaced ... do I need to get sensors as well?
any online stores sell the entire kit for MINI's?
sorry for all the questions but it will be my first attempt to do this myself.
Old Jul 14, 2012 | 09:50 AM
  #28
RJKimbell's Avatar
RJKimbell
This is what I put on the Fronts when I replaced both Pads and Rotors...
Akebono Euro Ceramic Brake Pads from www.TireRack.com!!
Old Jul 28, 2012 | 07:27 PM
  #29
lurch70's Avatar
lurch70
thanks ... I am most likely going to try those. DOn't seem to have many options brake pad wise for a 2nd Gen Non-S ...
did you get rotors from Tire Rack as well? what did you go with?
and how is everything so far with the new setup?
Old Jul 28, 2012 | 10:41 PM
  #30
RJKimbell's Avatar
RJKimbell
Zimmerman Brake Rotors R55 R56 R57 R58 R59 Cooper NON S
Put these on...Way Motor Works set me up!! I did have new Sensors put on as well, Dealer did the install. As far as performance I couldn't be happier, getting ready to order the exact same set up for the rears, Sensors down to 3mm even though OBC says I won't need them for 13,000mi.
Old Jul 29, 2012 | 04:36 AM
  #31
lurch70's Avatar
lurch70
Put these on...Way Motor Works set me up!! I did have new Sensors put on as well, Dealer did the install. As far as performance I couldn't be happier, getting ready to order the exact same set up for the rears, Sensors down to 3mm even though OBC say I won't need them for 13,000mi.
thanks, that price at Way Motor Works seems very steep...
I see these Zimmerman Rotors for about $100-120 (pair) all over the web
http://www.autopartswarehouse.com/sk...gs+Best+Seller
what makes the one at WMW $180?
Old Jul 30, 2012 | 08:59 AM
  #32
RJKimbell's Avatar
RJKimbell
Have you checked his site, I just looked for Rears $110!!
http://www.waymotorworks.com/zimmerm...per-non-s.html
Old Mar 9, 2014 | 03:17 PM
  #33
pepperstripes's Avatar
pepperstripes
If the sensors are intact the light should stay off.
I think for most people sensors are silly too. You can "trick" your sensors.... cut the ends off and attach the two wires with a connector and tie strap them out of the way
I don't want to use the brake wear sensors but I haven't been able to make the red BRAKE light turn off. I wrapped the ends of the wires together on the right-front and did the same on the back. I can't find a wire for a brake sensor on the left-front, is there one?
I also used the method in the video linked above to reset the brake service interval which seemed to work but the light still did not turn off. Any other ideas?
Old Mar 9, 2014 | 07:58 PM
  #34
ashchuckton's Avatar
ashchuckton
There are only 2 sensors, 1 front 1 rear.
Old Mar 9, 2014 | 08:21 PM
  #35
pepperstripes
OK,thanks. The light did turn off after I drove for a few minutes. Great to have it off after 6 months!
Old Mar 9, 2014 | 08:24 PM
  #36
pepperstripes
I just installed a set of these today. Found the best price at pelicanparts.com.
Old Mar 9, 2014 | 10:04 PM
  #37
Systemlord's Avatar
Systemlord
Does the EBC Red Stuff pads have less brake dust versus other brands? I want a pad that has equal stopping power as oem but without the dust!
Old Mar 10, 2014 | 01:27 PM
  #38
ashchuckton
Before you put EBC pads on your MINI do a search on pad separation failures.
Old Mar 11, 2014 | 02:25 AM
  #39
Systemlord's Avatar
Systemlord
Actually I'm aware of this pad separation failures which is why I'm waiting for EBC to start moving their updated pads that use a different method for avoiding the pad separation failures. These pad separation failures could get someone dead! I'll be very patient, one or more years.
Old Dec 3, 2014 | 08:32 AM
  #40
kxmini's Avatar
kxmini
My wife's RED brake light came on the other day ('08 MCSa). I assumed it was the brake sensor thing as the car has 60k miles on the original brakes. I got in the car today and noticed she is also getting the symbol showing the car up on a rack. I checked the manual and it says it's a "vehicle electronics failure" and not to continue your journey.
So she's put about 300 miles on the car since the light came on. Anybody out there ever seen this indicator and what the problem might be? I will add that she still has the original battery which I have heard that as the battery gets close to dying that you can get some weird things happening.
Old Dec 3, 2014 | 08:44 AM
  #41
ashchuckton
If you have a brake warning do not continue to drive the MINI until you find the cause.
Is there enough brake fluid in the master cylinder?
Have you inspected the brake pads?
Do those things & report back.
Old Dec 3, 2014 | 09:27 AM
  #42
son-of-mini's Avatar
son-of-mini
The car up on the rack may simply mean it is time for a brake fluid change.
Old Dec 3, 2014 | 02:07 PM
  #43
kxmini's Avatar
kxmini
Brake fluid level is ok. Changing oil and checking brake sensor now. Will post my findings later this evening.
Old Dec 4, 2014 | 12:18 PM
  #44
ashchuckton
I think the brake fluid trips a warning at 2 years regardless of mileage.
Old Dec 4, 2014 | 03:31 PM
  #45
kxmini's Avatar
kxmini
So the brake fluid is ok. Took the calipers off and pulled the sensor out and it hadn't even started to wear on the plastic. Reassembled everything and went through the reset procedure and now no lights. I guess it was for a brake fluid change. Hopefully the brake light stays off.
Old Dec 4, 2014 | 09:30 PM
  #46
ashchuckton
If it is time for a brake fluid change do it. Brake fluid absorbs moisture over time lowering the boiling point of the fluid. It also promotes corrosion in the braking system. It's not a very difficult job.
minimofo
Dec 26, 2015 11:45 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
