R56 Question on my first oil change
Old Sep 8, 2011 | 08:04 PM
Aber's Avatar
Aber
I'm planning on doing my first oil change on my '11 MCS (around 1000 miles) and was wondering if I need to change the oil filter as well or should that be good for awhile?
Old Sep 8, 2011 | 08:08 PM
bluefox280's Avatar
bluefox280
Good rule of thumb, if you're changing the oil you'll want to pick out the particulates filter too...
There's a considerable amount of old oil in the filter and housing; you'll want to remove any remnants.
P.S. Applaud to you for changing you oil in the first 1000 miles!!!
- Erik
Old Sep 8, 2011 | 09:46 PM
kukaepe's Avatar
kukaepe
Be sure to use either MINI branded oil or an oil with ACEA A3/B3 rating. There are only a few oils out that have that rating. Most readily available with this rating is Mobil 1 0W40 EUROPEAN FORMULA, you can find it a most parts stores and WalMart. The other acceptable oils are listed on the MINI USA Owner's Lounge. MINI is probably the only place to find a new filter that meets factory specs.
Old Sep 9, 2011 | 01:33 AM
MINImal lag's Avatar
MINImal lag
I, as well as many here at NAM, also believe in changing the oil after break-in, and at much shorter intervals thereafter, than the computers say to do so. I personally would never change the oil without also changing the filter.
Old Sep 9, 2011 | 06:39 AM
Gil-galad's Avatar
Gil-galad
+1 to everything stated in the replies thus far although OEM filters can be acquired through several online sources in addition to the dealership.
Old Sep 9, 2011 | 11:28 AM
Aber's Avatar
Aber
Thanks for the info! I'll probably swing by the dealership this weekend. Also, I picked up some Valvoline SynPower which is rated at ACEA A1/A5. Will I need to exchange that for the A3/B3 rating? Sorry, I'm not too familiar with that rating system.
Old Sep 9, 2011 | 11:34 AM
bluefox280's Avatar
bluefox280
BMW / MINI Long-life rating LL-01 Approved Synthetic Oils for the US Market:
  • Castrol Syntec European Formula SAE 0W-30
  • Mobil 1 SAE 0W-40
  • Pennzoil Platinum European Formula Ultra SAE 5W-30
  • Valvoline SynPower SAE 5W-30
- Erik
Old Sep 10, 2011 | 01:11 AM
Opeth's Avatar
Opeth
  • Mobil 1 SAE 0W-40
- Erik
Do you use LL01 in the US? Here, LL01 is the old type and the LL04 is the recommended type.
Old Sep 10, 2011 | 07:16 AM
bluefox280's Avatar
bluefox280
Yes, LL-01 oils are for applications within North America.
LL-04 oils are not recommended for gasoline engines outside of Europe because of the higher percentage of ethanol used in US-spec gas, and the LL-04 oil can increase the internal corrosion by reacting with the ethanol. See NOTE #2 on at the bottom explanining that the LL-04 oils are not to be used:
- Erik
Old Sep 11, 2011 | 09:59 PM
highlander709's Avatar
highlander709
I have always used Pennzoil or Quaker State full synthetic on all my other cars. Since those aren't recommended for the MINI, I have switched to the Valvoline SynPower full synthetic 5w30. I have been quite impressed with it thus far and would recommend it. I can generally find it for under $30 for a 5 quart container. I will stick with it. I find Mobil One a bit pricey. I now use the SynPower in all our vehicles. BTW, I am changing every 5K miles and I never change oil without changing the filter.
Old Sep 29, 2011 | 11:55 PM
MNMLST's Avatar
MNMLST
No oil change after break-in
I didn't change the oil after the break-in period, as I was too busy doing mods
Am I screwed?
I'm almost at 7k and barely gathering info on DIY oil change.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
serrow
Hawaii
Aug 19, 2015 11:35 AM
ludedude
Aug 10, 2015 07:16 PM
