R56 P0456 code
Old Sep 6, 2011 | 06:41 PM
EVIL KEN's Avatar
EVIL KEN
P0456 code
I'll try to make this short. I bought my new Mini Cooper S 4 weeks ago. The CEL light came on at about 400 miles. I took it back to the dealer and they said it was cured. couple days later CEL again dealer took it back and replaced a tank venting valve Pn 13-90-7-595-574. Said it was fixed. 2 days later CEL again. I called the dealer as soon as they get a loaner car they will bring it in. I called the Dealer today to check in and was told they have another one there with the same problem (DMTL issues) and as soon as they figure it out they will bring mine in for repair. Anybody else have this problem.
Old Sep 6, 2011 | 09:17 PM
bluefox280's Avatar
bluefox280
* Mini DTC P0456 - Evaporative Emissions System - Small leak detected
Could be something as simple as a defective gas cap, to as large as a torn EVAP hose.
The dealer should do a fuel tank pressure test to see if the system is leaking from the tank or elsewhere.
- Erik
Old Sep 6, 2011 | 10:03 PM
d4rd's Avatar
d4rd
Mine had similar problems with CEL coming on and off. Took 10 days in the shop. My progression at the dealer: new gas cap and gasket, reprogram ECU, test fuel quality twice, smoke test everything twice, wire check purge valve to controller, and O2 sensor, finally replacing purge valve (fixed problem). Most likely candidates: gas cap, purge valve/solenoid, DMTL.
Good luck
Bruce
Old Oct 29, 2011 | 05:33 PM
morphix's Avatar
morphix
My 2011 is in the shop for the 5th time to fix this error. Just got it back 2 weeks ago after waiting 3+ months for a part to come in and I put about 120 miles on the car and the engine light came back on.
Now I have a loaner and they are going to look at it Monday. Car drives great but it has been giving me the p0456 error since I few weeks after I got the car. Just fix it already.
Old Oct 30, 2011 | 02:13 PM
EVIL KEN's Avatar
EVIL KEN
I got mine back 2 weeks ago so far so good. They had it for 2.5 weeks replaced the tank venting valve 2 more times and finally the DMTL pump. I don't understand why Mini wouldn't replace the pump first it is a known issue. Bryan at Orlando Mini kept me informed of the progress and got Mini to cough up $500 accessories for my trouble.
Old Nov 3, 2011 | 06:21 AM
morphix's Avatar
morphix
Got a email yesterday but no one called for me to pick up m car.
Job #1
PROBLEM A CUSTOMER STATES CHECK ENGINE LIGHT ON
0000006 PERFORMING VEHICLE TEST (N/C)
6100720 PROGRAMMED/ENCODED CONTROL UNITS (N/C)
5153
SOFTWARE
INTER FAULT MEMORY, FOUND FAULT 321D- MICROLEAK DETECTED IN EVAP
EMISSIONS SYSTEM. TANK PURGE VALVE HAS BEEN REPLACED TIMES
PREVIOUSLY FOR THIS FAULT. SMOKE TESTED SYSTEM, NO EXTERNAL LEAKS
FOUND. UPDATED PUMA CASE FOR THIS VEHICLE, PUMA HAS NO FURTHER
INFORMATION AT THIS TIME. UPDATED COMPLETE VEHICLE SOFTWARE INCLUDING
CAS. PUMA CASE NUMBER
I have 4 other invoices in my inbox with almost the same text.
What is my next move? This is the 5th time they have had the car.
Old Nov 3, 2011 | 10:26 AM
Porthos's Avatar
Porthos
Lemon?
Old Nov 3, 2011 | 01:59 PM
EVIL KEN's Avatar
EVIL KEN
Check the Florida lemon law web site.
Old Nov 4, 2011 | 07:01 AM
morphix's Avatar
morphix
Thanks, reading up on it now.
Old Nov 4, 2011 | 05:00 PM
morphix's Avatar
morphix
got it back, so far so good. Software update, hope this is the last time...
Old Nov 26, 2011 | 11:23 AM
morphix's Avatar
morphix
...and it is back in the shop
3 weeks and light came back on.
Might have to get a lawyer...
Old Nov 26, 2011 | 12:49 PM
EVIL KEN's Avatar
EVIL KEN
Sorry to hear. I've put about 3000 miles on mine since I got it back and no more problems. Have they replaced the DMTL pump.
Old Nov 26, 2011 | 02:36 PM
morphix's Avatar
morphix
They replaced the pump twice from what I can tell, they also did the smoke test twice with no visible leaks.
I am a pretty easy going guy and I have had just about enough of this.
Old Nov 28, 2011 | 01:00 PM
morphix's Avatar
morphix
new DMTL pump in, fingers crossed...
please be fixed please be fixed
Old Nov 28, 2011 | 07:41 PM
mellocooper's Avatar
mellocooper
I used to get P0456 in my Mazda3 all the time. I just kept my scanguage in the map pocket to turn off the CEL and it would stay off for a while LOL.
It had over 120K miles when I traded it for the Clubman, still running fine!
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
