R56 Coolant Flush Procedure Anyone? UK guys?
Old Sep 21, 2010 | 10:31 AM
countryboyshane's Avatar
countryboyshane
Does anyone know if there is a radiator drain for the R56 S radiator? Is the only way to drain coolant from the cooling system to disconnect the bottom radiator hose and make a big mess?
Also, can someone comment on the cooling system capacity of the R56 S engine?
Old Jul 23, 2011 | 06:03 PM
ramtaajogi's Avatar
ramtaajogi
bump
Old Jan 17, 2012 | 09:52 AM
bugeye1031's Avatar
bugeye1031
Moderator
bump
Old Jan 17, 2012 | 10:20 AM
Minidrivr's Avatar
Minidrivr
No drain that I know of. The BMW service manual says to pull the bottom hose.
Old Jan 17, 2012 | 10:28 AM
niquemarshall's Avatar
niquemarshall
Yup it's the drain hose and/or heater core if u wanna get it ALL out... Just don't do like I did and forget to plug the heater core back up.. It may cause a problem LOL
Old Jan 17, 2012 | 11:04 AM
booktrout's Avatar
booktrout
Cooling System Capacity
____________________________________MINI Cooper__ MINI Cooper S
Cooling system including heater_____ltr______5.2__________ 5.2
Old Jan 17, 2012 | 03:06 PM
MatthewMateo's Avatar
MatthewMateo
Driver's side, under the car, move the two clips to the middle on the radiator hose. Pull and cuss a lot until there is an orgasm of coolant no where near your bucket.
The coolant system holds 1.4 gallons. Use 50/50 half mix.
To refill start the car, begin to pour it in the coolant expansion tank. You'll have to bleed the system at the same time.
Take a flashlight and look on the driver's side of the valve cover. Between the valve cover and intake, about 3 inches down is the coolant bleeder screw. Loosen it/take it off. Watch the air bubble rise and the coolant begin to exit the expansion tank and into the block.
Did it today.
Old Jan 17, 2012 | 03:29 PM
mini4tide's Avatar
mini4tide
Can you post a photo of the bleeder screw?
Old Jan 17, 2012 | 06:16 PM
mini4tide's Avatar
mini4tide
Nevermind, found it!
Old Jan 17, 2012 | 07:36 PM
MatthewMateo
Good! Sorry for the late reply. I just got the email from NAM.
I called a shop and asked them what was going on and that's what they told me.
Took me about 10 minutes before I was like... Okay! Found it!
Old Jan 18, 2012 | 02:09 AM
mini4tide's Avatar
mini4tide
Yeah, I pulled it out, dropped it, and had to dismantle the whole top of the motor to find it. Really no need to remove the screw completely. Coolant will bubble out around it if you loosen it. I don't recommend taking it all the way out. Thanks!
Old Jan 18, 2012 | 07:08 AM
Mini2na's Avatar
Mini2na
This would be a great "How To" post with pictures for the next person to do this procedure.
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Alwyn
Aug 26, 2015 04:53 AM
tylewis
Aug 18, 2015 06:53 AM
eliseo1981
Aug 6, 2015 05:00 AM
