R56 I'm learning... So whats the buzzing after it is shut off?
Old Aug 31, 2010 | 07:10 PM
RotaryGuy's Avatar
RotaryGuy
Finally brought the car home today after the ordeal with the 9 mile off the lot breakdown... Our 2010 Mini S makes a buzzing noise that sounds like a pump running for a few minutes after the car is shut off.. I was assuming that it is some sort of pump either circulating oil through the turbo or coolant through the turbo.. But then during my searches I found about 100 threads about 1st gen PS pump failures..
I have heard the fan run sometimes but this is not the fan it sounds like it is moving fluid.. At first it sounded like boiling water, then I realized that it was fluid moving..
Can anyone clarify?
Old Aug 31, 2010 | 07:15 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
The oil pump continues to pump oil through the turbo housing to help it cool after shut down.
Old Sep 1, 2010 | 04:03 AM
RotaryGuy's Avatar
RotaryGuy
Thanks, that is what I assumed.. I have always had to do silly cooldown procedures to avoid cooking the oil in past turbo cars I have owned. I had a passat 1.8t that was so bad about cooking the oil that it used to burn globs of synthetic oil that would eventually block the drain tubes..
Glad that there is a precaution on this car.
Hobine
Oct 7, 2015 04:52 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
nomar116
Electrical
Sep 20, 2015 10:26 AM
renchjeep
Sep 6, 2015 01:54 PM
MasterShaftner
Sep 4, 2015 03:52 PM
