R56 Oil Leak?
Old Jul 6, 2010 | 09:50 AM
izzyj's Avatar
izzyj
Oil Leak?
So I was rotating the tires on my 2008 R56 (cedric) when I was snooping under him just to look at stuff (i'm very curious) and to make sure everything was normal when I noticed the transmission? or differential? can't tell covered in oil. Its still under warranty so I suppose the first thing I should do is take him in to the dealer, pix below but has anyone seen this before or experienced it before?
Old Jul 6, 2010 | 11:34 AM
abonn
Axle seals would be my guess
Should be no question on warranty coverage
Old Jul 6, 2010 | 01:40 PM
daflake's Avatar
daflake
Yep, go to the dealer on that one.
Old Apr 20, 2013 | 03:35 PM
george_talbot's Avatar
george_talbot
Sorry for the thread resurrection but does anyone know what causes this leak as I have this...
Old Apr 20, 2013 | 04:06 PM
izzyj's Avatar
izzyj
Yep! It's the axle seal, I had the dealer replace it under warranty
Old Apr 20, 2013 | 04:08 PM
george_talbot
Many thanks
Quite a labour intensive job? I have no warranty sadly...
Old Apr 20, 2013 | 04:10 PM
izzyj's Avatar
izzyj
Many thanks
I'd love to be able to tell you but unfortunately I have no clue how intensive it is.
Old Apr 20, 2013 | 04:13 PM
george_talbot
ah ok no worries then. Thanks for you help.
Does anyone know the part number for the axle seal?
Old Oct 2, 2013 | 04:36 PM
PaytonR56's Avatar
PaytonR56
ah ok no worries then. Thanks for you help. Does anyone know the part number for the axle seal?
I second this question. Part number!?
Old Oct 3, 2013 | 08:15 AM
v10climber's Avatar
v10climber
Dealer replaced our axle seal under warranty as well at around 30k miles.
A DIY isn't hard. You will have to remove the axle however which means disconnecting the control arm from the knuckle and removing the axle nut. The drivers side axle is just held in with a circlip so just put a prybar between the axle and trans and give it a good pop and it should come right out. The passenger side isn't held into the trans at all but it's bolted to the engine so unbolt the axle support bearing thing and the axle will slide out of the transmission. Then just R&R the axle seals. Should just take a seal puller but I've not done it before.
Couldn't find the part # on RealOEM so idk about that.
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
