R56 Is this normal at start-up? Indicators.
Old May 13, 2010 | 06:26 PM
jujucooper's Avatar
jujucooper
Thanks for putting up with my newbie questions. The OM is really ridiculous. Two questions:
1. When I start the car, first the service date stuff comes up. Then next to the trip odo a yellow triangle with ! comes up for a brief second. This is all while the car is "setting up." No warning lights or anything after that. When you start up do you ever see that yellow triange next to your trip odo for a quick second? Is that a "test" of some sort?
2. I might be crazy, but it seems like when playing the iPod through the iPod USB port thing (I have bluetooth/iPod package) my car has weird "memory" problem. I always press RND for random, to make my playlist like a shuffle. Sometimes when I leave and restart the car the RND is checked, and other times its not. Is there a way to make it so RND is always checked?
Thanks!
Old May 13, 2010 | 09:48 PM
Oakland Raiders Mini's Avatar
It only happens to me if I turn on the car 1st without putting on my seat belt.
Old May 14, 2010 | 12:06 AM
fongj's Avatar
fongj
Thanks!
Just a sanity check, but are you using the same key fab every time?
I needed to re-park my Mini yesterday night, so I grabbed the extra key fob by the door instead of my usual one, and was surprised when the radio was on when I started the car -- since I purposefully had it off the entire day -- plus it was set to a station I never listen to. Then I realized the radio settings were from when a family member last drove the car using the spare key fob. The Mini remembers this kind of stuff (plus other setttings) and associates them to each key fob.
Old May 14, 2010 | 04:24 AM
schatzy62's Avatar
schatzy62
This is normal operation. There is a timing circuit that if you get back in the car before the circuit has timed out then the memory of the RND is saved after the time out the memory of that is lost so it reverts back to standard mode.
You will also find this when playing a CD. If it is in the middle of a song and you go into the store and come back out about 5 minutes later then it resumes from the point in the song it stopped. If you spend more than half an hour in the store the CD will start from the beginning of the song.
You will notice that if you shut the car down with one press of the start/stop button and then get out of the car the radio will play for about 15 minutes until the timing circuits time out.
Again this is normal operation.
Old May 14, 2010 | 05:24 AM
jujucooper's Avatar
jujucooper
Thanks. You guys are the best!
Old May 16, 2010 | 05:50 PM
isthar's Avatar
isthar
I can't say I call forgetting settings like random a feature thought... I'd say it's clearly a bug!
PsychoRallye
21
Feb 17, 2019 06:08 AM
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
navybsn
Oct 4, 2015 03:27 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
Miniwaukee
Sep 29, 2015 09:22 AM
