R56 Red reflector on top of tach?
Old Jan 21, 2010 | 10:35 AM
pfriedel's Avatar
pfriedel
I've looked around, and read through the manual (honest!), but I can't find anything that explains what the hell the red reflector/lens on top of the tach is there for. I can't actually see it when I'm driving, so it might be blinking out Elvis' last will and testament in morse code for all I know.
Old Jan 21, 2010 | 10:37 AM
bulldoggirl's Avatar
bulldoggirl
My fiance asked my MA what it was and I honestly can't remember what he said...now I'm curious too!
Old Jan 21, 2010 | 10:50 AM
iwashmycar's Avatar
iwashmycar
its for the alarm, if equipped. It would flash
Old Jan 21, 2010 | 10:52 AM
kalililly's Avatar
kalililly
Security system light...
Oops...Adam got it before I posted
Old Jan 21, 2010 | 10:55 AM
pfriedel's Avatar
pfriedel
Reasonable. I wasn't sure if it might be something like a shift point indicator or something annoying like that.
Old Jan 21, 2010 | 11:27 AM
iwashmycar's Avatar
iwashmycar
Nope thats another option from JCW that would be just on top of the column
Old Jan 21, 2010 | 12:05 PM
RJKimbell's Avatar
RJKimbell
On page 24 of the 2008 Manual it is described as a Display on the Revolution Counter.
https://ol.miniusa.com/auth/ViewMINI...NI_Clubman.pdf
Old Jan 21, 2010 | 01:24 PM
pfriedel's Avatar
pfriedel
Ah, that would explain why I missed it, I saw "Alarm system" and skipped right past it, since it doesn't apply to mine.
Old Jan 21, 2010 | 02:48 PM
Yakatak's Avatar
Yakatak
Hmmm. Wonder if a bulb is installed there, even without an alarm system. Would be easy to install a simple pulsar circuit to make potential thieves think twice.
Old Jan 21, 2010 | 07:34 PM
markusw's Avatar
markusw
The alarm retrofit kit doesn't mention installing a bulb, so I guess the bulb is already there.
Old Jan 21, 2010 | 07:49 PM
blitzcat's Avatar
blitzcat
The leds are already there
Old Jan 21, 2010 | 08:08 PM
Babalouie's Avatar
Babalouie
Que Twilight Zone music...I just noticed that thing for the first time tonight and wondered what the heck it was.
Old Jan 21, 2010 | 09:17 PM
pfriedel's Avatar
pfriedel
It is awfully easy to get into the tach - a pair of T27 (T25?) bolts, a trio of Phillips head screws, and it's ready to fall apart in your hands. I'm not sure if there's a convenient plug that would allow you to remove it from the car, and whether or not there's a permanently powered branch up that way when the key is out of the ignition, but it is an interesting idea.
Old Jan 22, 2010 | 12:16 AM
DWright's Avatar
DWright
So that's what that thing is for! I was noticing it the other day(Monday) after my wife and I bought her a new '10 Cooper and wondered what the hell it was for. Now I know... and knowing is half the battle.
Old Jan 22, 2010 | 06:04 AM
RVExotics's Avatar
RVExotics
Whew, well at least I now know I won't have to redline it find out what the heck that thing is!
Old Jan 22, 2010 | 11:59 AM
rkw's Avatar
rkw
The LEDs are soldered directly on the circuit board. It wouldn't be worth the risk to try to use them (you'd have to cut circuit board connections) but there's plenty of room to add your own, separate lighting.
Old Jan 22, 2010 | 01:28 PM
brettno1's Avatar
brettno1
A side note on the red reflector: it is notorious for causing a rattling sound at around 2000 rpm. You'll notice that it's loose (you can move it back and forth with your finger) and it's been the cause of numerous people (inlcuding me) going crazy trying to stop a rattling sound that sounds like it's coming from the dash. It's actually the reflector vibrating.
Old Jan 24, 2010 | 09:14 PM
Blainestang's Avatar
Blainestang
Next time I can't figure out where a rattle is coming from (it's usually not the car, actually, but something like a cup/change/etc in my case), I'll check to see if it's the reflector.
Thanks for the heads up.
danielbrookes_9
Oct 3, 2015 12:51 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
Aug 12, 2015 01:24 PM
