Got an Alta turbo inlet hose due in tomorrow. How do you disconnect the PCV hose from the OEM hose? Don't see a clamp so do you just pull it off? Also, should I clamp it to the new hose?
you will need one of these to remove the hose. Harbor Freight under $5
http://www.jiffysupply.com/servlet/t...Removal/Detail
wouldn't hurt to clamp it
Thanks much. Off to Harbor Freight and see if I can get out of there with just one thing! Originally Posted by DAVESTER
you will need one of these to remove the hose. Harbor Freight under $5http://www.jiffysupply.com/servlet/t...Removal/Detail
I will say that the "nose picker" tool posted is one of the tools I used the most during moost tube installation, especially hard pipes. It's also great for intimidating your neighbors while having a grimacing look on your face!
Quote:
There is some many ways I can reply to that but I might offend the intire interwebs so I will leave it alone.Originally Posted by DAVESTER
theres Viagra for that problem
