R56 Air intake manifold question
I was poking around in the engine compartment after getting my car ('08 MCS) out of the shop and came across something that seems a little weird.
Question: the plastic air intake tubing, which runs from the front grill area to the air filter box, is just "sitting" in the opening of the filter box. Is it supposed to be secured somehow? Seem as if it should have a clamp, a force fit maybe....something.
TIA
TIA
OK, thanks...that's what I thought. Just push in and twist? Will I feel or hear something that tells me it's secure?
Reverse all the steps to secure the air filter box back into position.
Hope this helps.
It should take no more than 15 minutes.
Thanks slinger...I tried to simply twist and push and that didn't work. So I really appreciate the instructions. I'll give it a go tomorrow.
Looks like the tech did't get it all buttoned up after the timing chain work.
The tech is rather sloppy.
Got it. Went smoothly following your directions and now everything is buttoned up nice and tight. Thanks again...I'm noot sure if I could have figured it out with out your help.
One little clarification I might add: "This is hidden between the tube going into the engine and the box on the left hand side of the box". That little hose can be popped off thus exposing the T-25 torx screw.
Good point. You are correct that the tube can be removed.
chrisx18240
26
Mar 16, 2022 09:56 AM
Indimanic
Aug 19, 2015 11:08 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
