R56 Hole in tire Sidewall. Is it Patachable?
Old Jun 22, 2009 | 09:48 AM
ninjavan1sh's Avatar
ninjavan1sh
Hey Guys,
Noticed my tire was low on air, so i tried to fill it up. Then noticed air escaping out of a hole in the sidewall (no idea how this happened).
I am running Dunlop Run Flats (factory MINI tires), and was wondering if sidewall holes were patchable. Thanks!
Old Jun 22, 2009 | 09:56 AM
bonehead04's Avatar
bonehead04
Absolutely not. Once the sidewall is violated, that tire is toast.
Jeremy1026's Avatar
Jeremy1026
Moderator
Probably not. Since the sidewall is where the strength is to make a run flat a run flat. You are likely looking at a new tire. Especially since bubbles in the side wall mean new tires, I can only imagine what damage a hole would be.
Old Jun 22, 2009 | 10:31 AM
tambi's Avatar
tambi
Make sure you check the wear on the other tires if you're replacing this one.. One brand new tire with the other three (somewhat) worn out might lead to trouble..
Old Jun 22, 2009 | 10:39 AM
sequence's Avatar
sequence
uh, that'd be a "no." Sidewalls on RSC's are designed to provide support in case of a flat. If U wish to replace yr. runflats, consider the Continental Pro-contacts that are on many of the 2009s. I have them on mine and they're sooooo much better than the Duncraps I had on my 05--and about half the price.
Oxybluecoop's Avatar
Oxybluecoop
Check the marketplace for a replacement tire since those damn things run almost $300 a piece.
Old Jun 22, 2009 | 10:42 AM
sequence's Avatar
sequence
That's why I suggested the Contis--DT quoted me $170/ea out the door when I bought my replacement warranties last dec. Dunflops were still hovering around $300. I think U pay for the name here.
Old Jun 22, 2009 | 10:47 AM
ninjavan1sh
do you have the model name for the Contis?
Old Jun 22, 2009 | 10:51 AM
sequence's Avatar
sequence
Continental Pro-Contact.
Old Jun 22, 2009 | 11:03 AM
NightFlyR's Avatar
NightFlyR
I have 2 Spare Dunlaps in good shape. 195 55 16 not mounted, if you want one, its yours just pay the shipping as they are taking up space in my garage
Old Jun 22, 2009 | 11:24 AM
Oxybluecoop
Our posts hit at the same time!
Old Jun 22, 2009 | 12:56 PM
ninjavan1sh
Hey thanks, but i have 17's :D
Just ordered Kumho run flats (a pair) for under what one tire would cost from dealer. WOO!
Old Jun 22, 2009 | 03:29 PM
Mato's Avatar
Mato
You should use the same tire all around, otherwise there will be some traction issues... well if you play alot with you car or in bad weather conditions
Old Jun 22, 2009 | 03:44 PM
minimarks's Avatar
minimarks
Rule of thumb I've always followed is to replace a tire once the sidewall has been compromised and you should try and match it to the other three tires.. 2cents
Old Jun 22, 2009 | 04:13 PM
thevelourfog's Avatar
thevelourfog
If you put in a temp patch, only drive it to the tire shop to get a new tire.
Waszak
Oct 21, 2017 05:55 PM
actualsize37
Nov 18, 2015 08:58 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
mimaal
Sep 4, 2015 09:09 AM
Ntety
Sep 2, 2015 08:39 PM
