R56 O2 sensor spacers
Are you talking about something like this: (spacer is the silver part)
That's used to move the O2 sensor out of the exhaust stream to "fool" it into thinking everything's working correctly in the catalytic converter (even if the converter's not present anymore). It's the same principle as the "O2 simulators" you see on the market - basically a way to run without a cat or with a gutted cat and not throw a "check engine" light.
I don't recommend messing around with or disabling any sensors that are used to determine the air/fuel ratio in the engine, but evidently it works for some people.
yo i got a question I but those spacers in from alta proformance and like a day later when i was drving on the free way i got a engine code p0136 looked it up and its says a slow 02 sensor or something like that post cat? Did i not tighten it down enough? i used graphite on the spacer threads and on the threads on the o2 sensor, could they be dirty? . I have a scan guage2 and cleared the code. Is it possible that the code will show up again ? and what actions would should i take to make sure it doesnt come on again.
Not my sensors - just a random picture I found to illustrate the spacers. I think the point of the double spacers is in case one spacer isn't enough to get the O2 sensor completely out of the exhaust stream.
As for your "slow O2 sensor" fault, I'm wondering if it might be because the O2 sensor isn't getting hot enough to work properly.
Talking about O2 sensors, I recently had to remove an 03 Hyundai downstream O2 sensor. To put it kindly, it was a PITA. I nearly yanked out the exhaust in the process. This was after penetrating oil was used, heating up the vehicle, using a hot torch, etc. I'm tempted to remove the O2 sensor on the new Clubman and make sure there's anti seize or something to make sure this does not happen to me if I need it replaced.
Anyone with experience removing the O2 sensors a few years down the road?
Yea I tried to remove my post-cat sensor today with a 6-inch adjustable wrench and I stood no chance in hell of getting it loose. Going to pop's tomorrow to get some better tools!
This is a very good idea. I just might do this with all the bolts on the exhaust. I <3 anti-seize.
sempaipaul
Sep 18, 2015 03:05 PM
