R56 How to open trunk?
#27
I think not having a boot release on the interior is probably a safety feature; you wouldn't want to accidentally bump the switch going 60 mph on the freeway and have the boot lid fly open with all your worldly belongings shooting out of the back of your MINI, causing a major pile up.
If you must release the boot from inside the car, use the keyfob. Yes I know you have to turn off the engine in order to take the keyfob out of the slot so you could press the boot release button, but think of it as a safety feature where it prevents the exhaust from flowing back into the cabin while the boot is open and kill you.
#28
#29
I was being semi facetious. I'm sure someone had accidentally hit the switch while the car is moving before.
I did use the release to "punk" my friend, but we were parked. He had me look for something in his glove compartment, and I saw the trunk release button, and said, "what does that do?" and immediately pressed it, so he has to go out and close the trunk. Did that three times in a row.
How about the second point?
#30
#31
Geesh, somebody woke up on the wrong side of the bed today.
I was merely helping to come up with theories as to why there isn't a boot release in the R56, and justify/compromise the lack of that particular feature.
As to the exhaust, I usually turn off my engine if someone is getting something out of the boot, it's more of a courtesy, so that they don't have to smell the fume while getting something in or out of the boot, particularly with the S model since the exhaust pipe is right in the middle.
I apologize for responding to your post. I wasn't aware that attempts of humor isn't allowed in this thread. You should set to ignore my posts in case you come across my other posts.
#34
#35
#37
open mouth - insert foot - ok here I go
My mini is a non S and I am not sure if we are talking S only here. On my boot door I can hold down the key boot button and it actually pops the door open a bit - so not only unlocks but unlatches. I also set the settings in the speedometer so that when I unlock one door they are all unlocked - I really really like it like that. It was the hassle of the boot that made me set it up like that.
Thanks!!
#38
You don't have to unlock any doors to open the boot w/key-fob, but it is a good idea as it locks again when closed. Too easy to drop key-fob in there by mistake and lock yourself out. CA system won't allow it, but no protection from standard system.
I have my key-fobs both programed for single touch unlock of everything, primarily for gas stops and boot loading ease.
Alpha Motoring
09-07-2020 07:34 PM
BackcountrySkier13_inAZ
10-14-2015 06:00 PM
