R56 Plastic dash cover (by your knees)
Old Feb 19, 2009 | 02:43 PM
barthol's Avatar
barthol
The plastic cover for the dash under the steering wheel (by the driver's knees) keeps popping open when I hit potholes (17" run flats).... it is happening with greater frequency now.
Anybody else have that problem? Is there a solution? It seems to just be a snap-in tab that gets loose very easily.
Old Feb 19, 2009 | 03:25 PM
pepegrande008's Avatar
pepegrande008
when putting back in place, make sure to push firmly and make that it "Pops" back in place. you will here all the pop (there are a couple) when it is back in place properly.
-J
Old Feb 19, 2009 | 04:32 PM
lacning74's Avatar
lacning74
after removing it several times, mine is a little loose and pops open occasionally as well at the top right corner where there is a plastic tab that got bent. i had to unbend it and make sure it snapped into the square hole nice and snug. pulling upwards while pushing it in helps. hope i didn't confuse you more.
i added the pic from realoem. it's that tab to the left of number 5 that come loose for me.
Old Feb 19, 2009 | 08:53 PM
Minidrivr's Avatar
Minidrivr
Mine was that way after delivery. The car came with OEM driving lights and this panel was removed and reinstalled during that. After a few bumps I found the panel was squeaking and not fully clipped in. Even though it felt fine after I clipped it back in place, it would never stay over rough roads.
The dealer replaced the clips that hold onto the plastic tangs and it has been perfect ever since.
From the RealOEM image, it's the #8 pieces that hold #7 in place.
Old Feb 21, 2009 | 12:42 PM
barthol's Avatar
barthol
Thank you all..... I think I will have the tabs replaced. Mine is coming open a lot with new england potholes and runflat tires.
Old Feb 23, 2009 | 06:06 AM
Sparks's Avatar
Sparks
Just saw this.
There's a trick to getting this on and staying on.
On the bottom of the panel, 3 screws hold on the panel. Take these off and the panel will fall off.
Make sure the top is hooked correctly with the tabs, then screw it in again. May take a few tries.
I was in the dearlership twice for this and they "fixed" it by adding some sort of goo to the tabs.
Old Feb 23, 2009 | 12:08 PM
djam43's Avatar
djam43
Yes, the tabs need a little lube, for them to be fully seated.
Old Feb 23, 2009 | 12:16 PM
meadbar's Avatar
meadbar
Hi djam you could do with a tie to go with that colar on that pint lol!!!
Old Feb 24, 2009 | 12:55 PM
kyounger's Avatar
kyounger
Panel Clips
I have the same driving lights and had the same problem. The dealer fixed it.
Keith
09R56
Nov 16, 2022 10:49 AM
kazyn
Oct 25, 2019 02:34 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
trw92a
Aug 26, 2015 01:47 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
