R56 Yellow triangle with ! in odometer window?
I just finished installing an Alta CAI, all went well and the installation was easy. (As part of the install procedure, the battery is disconnected.) When I hooked things back up and went for a test spin, I noticed a yellow triangle with and exclamation point inside between the total miles and trip odometer reading. Can't find it anywhere in the manual..... any clues?
-dont know about 2nd gen cars,but on 1st gen's this can be turned on/off by toggle switch.-look for one marked dsc or asc.
If you see icon illuminated,then traction control is disengaged(more fun)
Just went for another ride and solved the problem. Turning off the DSC showed the larger triangle in the upper tach window and the smaller one remained between odometer read-outs. Turning DSC back on cleared it. :-)
I was guessing that since I didn't have the tach display set to MPH and not to "Range" it was trying to give me a head-up that I was about to run out of gas!
When you start up your MINI whatever is causing that small warning triangle should show in your main tach display followed by a chime.
That light stays on as a reminder that something needs addressed.It comes on for low gas,oil service,brake service,TPMS issues,CEL,disabled ASC.If you don't have any alerts in your tach at startup and this light is on I'd call your SA.
sssevita
Mar 20, 2016 06:24 AM
Samhillrocks
Sep 29, 2015 12:55 PM
Sep 29, 2015 12:11 PM
Emnotek
Sep 29, 2015 07:37 AM
