R56 Feeling Torque Steer!
When you apply a considerable amount of throttle and you then feel both the car and steering wheel pull in one direction, in my case the car will pull to the right. That is torque steer.
see: http://en.wikipedia.org/wiki/Torque_steer
I test drove a Cooper S with the JCW last week. I felt the torque steer as understeer whenever I got on the throttle exiting a corner. I've asked about it on the JCW and have been told it can be reduced with adj. camber plates and adjusting tire pressures.
Coming from an M3 it is definitely strange to experience.
Thats what happens when LSD is implemented, no?
Even though BMW tried to avoid this torque steer by centering the tranny as much as possible and therefore having axles of equal length, you can still feel some. Not much in mine. Check tire pressure, alignment, etc.
Follow-up question: The broad discussion in the forums leads one to believe that torque steer is more prevalent in the R56 (w/turbo) than in the R53. Is this true, and if so, what specific design change exacerbated its effect?
I think the opposite. To my knowledge, the difference length between right and left axle is less in the new mini than the old one. Power is very similar. Other things to take into consideration between different trims of same generation is the suspension type. Something that helped the first generation Mini is that the suspension was stiffer.
+1 mine does this too, any correction at the steering wheel results in over correction
According to Motoringfile's source at MINI torque steer was the reason for LSD not being available on the factory JCW. Apparently the EDLC system actually all but eliminates torque steer. I'll report back next week with the proof, or lack of it, in the pudding!
RC pinned it down: R53s have much less TS than R56s because of the (old) engine's narrower torque curve. the supercharged tritec gains its maximum torque from about 3k to 5k rpm, while the turbocharged prince's peak torque curve is much broader, from barely above idle to 5K--thus more torque at lower launch rpms. I own a R53, and have rarely felt the kind of TS that'll slap U in the *** to hang on in R56, at least the manual models, having LSD didnt seem to make a dif really. The manual Clubman S I drove with the LSD had it real bad, to the point of annoyance. I though I was driving a SRX or Golf GTI!
But with the MCSa I didnt feel the TS as much as the manual from launch, and rarely on the highway when I stomped down. maybe the torque convertor tames it down some. To me the difference was enough to go with the automatic (that, and other reasons. I love paddles, and my left knee is shot.)
mine has lsd. i actually tried adjusting tire pressure so maybe that helped. one front tire was about 3psi lower than the other. i reset all to 33psi
one way is if you launch the car at a dead stop the wheel will want to jerk to one direction. the other way is to give it enough throttle to let the wheels spin. if you have one line of rubber you dont have limited slip
One night at about 11:00 PM I was coming home from an evening class about 100 miles from home. I was tired. There was a car a little ahead of me on the freeway in the lane to the right. He exited at an off ramp and I made a sympathetic move to the right. About half of the car crossed into the next lane and I moved back. A CHP behind me stopped me to see if I was drunk. I wasn't and he let me go and said get upto speed before getting back on the freeway, so I punched it. The car pulled one way then the other. I was sure he was going to stop me again.
LSD should delay the interference from ASC. So I think it is worthwhile.
I have LSD on mine, and I really feel it under WOT conditions above 3500 RPM
if the road surface has any imperfections or gravel, watch out
I never feel it going around corners fast, in fact sometimes I can feel my inside tire spinning
really the only time I feel it is on straightline WOT 1st and 2nd gear
