R56 Things Not In My Operator's Manual
Old Jul 27, 2008 | 09:44 AM
  #26
krim's Avatar
krim
Originally Posted by mellocooper
I think I read somewhere that the '08s don't have the pull thinggy for the hatch. :(
that does seem to be the case, i just lifted my rear seats to check for it and there's no ring under the seats. The two round things and a couple of pieces of masking tape were all that was down there.
Old Jul 27, 2008 | 11:32 AM
  #27
Robin Casady's Avatar
Robin Casady
Originally Posted by rrcaniglia
Reference the Dynamat, Scottab36, would the installation affect the fit of the seat when put back? I presume the boot would be easy to do because you can get to the metal easily, but do you have plans to do the front floors? Aren't the 'rugs' glued down? Don't you have to cover the side panels and wheel wells to get good attenuation?
No, I don't think it would affect the fit of the rear seat.
I would like to do the front. Haven't tackled it yet. I don't know about the rugs. Where did you hear they were glued? The doors are extremely difficult to do, other than putting a few small pieces in near the bottom.
I'd like to do the firewall and floor. Don't know how difficult it will be.
And how good is this stuff, really?
It deadens vibration of metal panels. After removing the rear seats, the noise from that back was very loud. I put Dynamat throughout the back, I also put Quiet Batt in the side panels and in the cavity for the rear seats. A birch plywood floor went over the seat cavity. I believe the sound level from the rear is now lower than when the seats were there.
However, there is still a lot of road noise coming in the front.
For the full story, see this thread:
https://www.northamericanmotoring.co...d.php?t=117453
Old Jul 27, 2008 | 04:30 PM
  #28
rrcaniglia's Avatar
rrcaniglia
Robin,
You can't believe how impressed I am that you have the guts to take your MINI apart to this extent.
I noticed in your middle pic a cable and ring on the right side that looks like the boot hatch manual release ring. Is that the one you showed a pic of earlier relocated so you could lay in the Dynamat?
Old Jul 27, 2008 | 05:07 PM
  #29
scottab36's Avatar
scottab36
Dynamat
After installing Dynamat in the boot and on the inside of the boot hatch there was an audible reduction in noise coming from the rear of the car. It is much nicer to drive now!
Old Aug 7, 2008 | 06:03 AM
  #30
mysticturner's Avatar
mysticturner
Originally Posted by mysticturner
Our 2006 had it under the rear seat. I had to use it once. When I got our 2008 I found it (well something) there as well. I was pulling the rear seats to do a fabric protection job on them and found the plastic pull thing - and it was connected to NOTHING! I wonder how it transmits the fact that you pulled on it to the latch?
It's on the list of things to get checked out when I take it in August 4th.
Well I took Bimini (our 2008) in and had this looked at. I found out that during the 2008 model year the emergency boot release has been deleted. Bimini is a production week 17 (I think - might be 19). The dealer thinks the fact that mine was not installed properly is indicative that the training on the deletion had occured, but they were still installing it. Person A put in the part, Person B was supposed to complete it but thought they were no longer doing the install. And I think there was someone with a May build that didn't have a release.
Anyway, they installed it and it's in the boot proper, not under the seat. Kind of a bad design in my mind. The dealer said it was so that you could position yourself to push up the boot from the inside after you opened it. My argument is that I can pull the ring while leaning in, the boot pops enough to unlock, I can then walk around and open from the outside. And where it is now, if the seats are up, I can't get to it unless the boot cover is not in place or I want to bend/break the boot cover. This might have to get modified.
Old Aug 7, 2008 | 12:20 PM
  #31
pilotart's Avatar
pilotart
Mine was build week 12, date on tag in boot is 19 March 2008, no evidence of release cable seen under seat or boot.
There is a petrol door release (green pull) behind amplifier in left access port.
Looking at this photo from Robin's post above:
The release cable can be seen from the latch, along right side up under that wire bundle
with the masking taped NAV receiver connector.
No evidence of this cable in mine, it looks like Robin has relocated the pull-ring along upper side wall in this photo.
Robin lists "NAV" as installed, was the receiver removed for the above photo?
Or is it located elsewhere, I find this space ideal to hide a 'jumper-cable' set and as long as I have enough battery to release the boot..
matthewbrakeii
May 13, 2021 08:39 AM
theblackfalcon
Oct 11, 2015 09:49 AM
imanexcellentdriver
Aug 31, 2015 08:08 PM
tylewis
Aug 18, 2015 06:53 AM
minipopkart
Aug 13, 2015 05:22 AM
