R56 MINI ranks next to last in initial product quality
Old Jun 5, 2008 | 10:05 AM
  #51
Guest's Avatar
Guest
Originally Posted by mysticturner
I have a pretty strict standard of quality and below is the definition. To most people 'Quality' is a sort of feelie, unquantifiable thing. We need to learn that Quality is definable, measurable, and attainable.
To get a rating of good quality, two conditions must be met. The first is that only one problem is found in the first 1000 miles. If nothing comes up, then that one gimme expires. The next problem cannot come before 80,000 miles. Note that 'problem' is defined as anything other than gas or oil or tires. I might give brakes a pass but I did have a VW go 240K on factory brakes, so unlikely.
I've developed that standard because I've found that some of my other cars can meet that standard. To get to great quality, the car has to go to 100K before problems. This level can be reached.
By that standard, Tinkerbell (the wife's 2006 MCS) is unable to reach a rating of good, as there have already been problems, even though the dealer has attended to those issues. Time will tell if Bimini will make it there. But I have to admit - We're having so much fun that the few problems we've had seem unimportant.
Great example of why these survey's are meaningless!
If you think ANY modern sports car is going to go to 240k miles on factory brakes, you're smoking something. To expect that a car go to 80k miles and never have a single issue (Squeak, creak, rattle, etc) you've basically ruled out about 98% of the cars on the road today from EVERY manufacturer.
This isn't a 1972 VW Rabbit with a stereo and an iron block that goes forever. You've got computers that monitor the brakes that are more powerful than the computers that sent us to the moon. Cars are complicated now a days, and as such will require more fiddling. Expecting a modern car to go 100k miles without any reason to take it into the dealership is so absurd it's laughable.
Old Jun 5, 2008 | 10:39 AM
  #52
mellowmcs's Avatar
mellowmcs
Originally Posted by devexpert
Well it is quality fault either way isn't it? The manual is either not clear enough or feature is poorly designed so you need to read manual to use it... There should not really be a single feature accessible from driver seat that you would need manual for.
Every single German car I owned for example had electronics problems, from auto AC not working correctly to Bluetooth and iPod adapters.
Japanese cars I had, did not have these problems and worked great on another hand.
Most people are not enthusiasts and don't hang around here. When something does not work for them they say its a fault. Its a valid point.
I don't disagree that it could be a quality issue but for most people when they see the JD numbers, they automatically assume that each was a hardware failure of some sort.
I would like to see one number for customer usage complaints and one for where things actually broke or failed. but that's just my preference.
Old Jun 5, 2008 | 12:21 PM
  #53
MotorMouth's Avatar
MotorMouth
Well it is quality fault either way isn't it? The manual is either not clear enough or feature is poorly designed so you need to read manual to use it... .
I'd have to call that ridiculous. If you want something that simple you'll need to stay in some very old cars indeed - or stay out of anything with modern comforts.
Try jumping into a modern 30k+ car and for sure there will be something you need a manual to learn how to do (or someone to show you). You ever looked into a mercedes or bmw (esp. a 7 series)? It's as bad as an airplane cockpit. I bet you couldn't even put a 7 series into "drive" if someone didn't show you how to do it. however once you know how it is very simple.
Ignorant (different from stupid) people who don't read the manual should not be a reflection upon the car.
Old Jun 5, 2008 | 12:36 PM
  #54
chris410's Avatar
chris410
Originally Posted by howie289
The average Mini has 1.6 problems, the average Lexus has 1.0 problems, the industry average is 1.2 problems. Is this really such big difference?
Also, the average Mini has alot of gizmos, doodads and thingamabobs (more things that might break).
Exactly, example...
My Lexus IS300 which was had all the maintenance performed and was nothing more than a daily driver had the transmission fail at 30k miles. Lexus replaced the transmission and said this was a common issue.
At 68K miles, the motor blew! To this day I do not know what happened but it was out of warranty so I had to buy a motor and have it installed. My wife's E36 M3 had a number of electrical issues, my E36 M3 ended up with a blown water pump, rear differential cracked in half...driving 45mph straight...and had a number of electical issues.
Needless to say...any and all cars have issues, go to Toyota, Honda, any of the top makers and hang around the service department for a bit and you will realize they all have their fair share of issues.
It comes down to build quality, maintenance, and design. Some cars will run without issue, others have a lot of issues, my theory is the basic quality of construction initially, quality of parts, and a product of upkeep, useage, and of course environment dictate the reliability.
Old Jun 5, 2008 | 01:07 PM
  #55
TheBigNewt's Avatar
TheBigNewt
This survey didn't sound like it had anything to do with reliability nor did it have much to do with quality/build issues from the factory (did anyone actually fill one of these 200+ question surveys out?). The post about early Minis getting docked by JD Power because of the lack of cupholders supports that. CR does more of a reliability survey, which is what this thread's posts is talking about, not stuff like "do you have adequate places for your drink". I'm sure the survey influences the public car buyers, so Mini takes it seriously. Mini resale values are very high, partly because we pay MRSP of course. But without knowing what the survey asks I can't draw any conclusions as to what it means as far as the car being manufactured well (mine's been perfect).
Old Jun 5, 2008 | 04:08 PM
  #56
rickdm's Avatar
rickdm
So it seems like the message a lot of you want to send BMW/Mini is; 'ending up next to last in a national initial quality survey published in every paper in the country doesn't mean anything, the survey is crap, don't worry about trying to improve the cars because we love them jut as they are.' Did I pretty much capture it?
Old Jun 5, 2008 | 06:01 PM
  #57
sikamini's Avatar
sikamini
No. It is a concern and BMW/MINI should address it. I take issue on the statistical side. These numbers are like arguing over a fraction of an inch when measuring a 200' long building. The difference is insignificant. However, you have a point, perception becomes increasingly important when measured values are no longer visible to the eye. Peace and happy motoring!
Old Jun 5, 2008 | 06:44 PM
  #58
NJP's Avatar
NJP
Originally Posted by jggimi
"J.D. Power and Associates’ Initial Quality Study is based on responses from more than 81,500 purchasers and lessees of new 2008 model-year cars and trucks surveyed after 90 days of ownership. The study, which was conducted between February and April, is based on more than 200 questions designed to provide manufacturers with information to facilitate problem determination and drive product improvement."
Note though, that the industry leaders rank less than 2X better than the industry laggards.
WELL! I own the last 2 cars (MINI & Jeep) & LOVE 'em both. Maybe the study is wrong? Wouldn't trade the Jeep when we bought the Mini & won't trade the Mini unless we buy another Mini. Take that, JD Power.
Old Jun 5, 2008 | 07:09 PM
  #59
Gil-galad's Avatar
Gil-galad
I just noticed that the Detroit Free Press can't spell Isuzu. Guess their graphics department was too busy watching the Red Wings when they cranked this out...
(BTW, the Isuzu sample size is smaller than MINI? Maybe true, but I find that surprising.)
Old Jun 5, 2008 | 07:17 PM
  #60
lhoboy's Avatar
lhoboy
Anyone know what gen MINI was included in this study? If it was 1st gen cars, I'm surprised the MINIs didn't come in dead last. I love my car but its spent moe than 5% of it's life in the shop (all electronic/electrical issues). I'm hoping they weren't yet looking at the 2nd gen cars. Otherwise I won't hear the end of it from my wife (we're about ready to order a new MINI for her).
Old Jun 5, 2008 | 07:20 PM
  #61
ckranert's Avatar
ckranert
Grain of Salt
Like others have said the survey is questionably reliable. My Porsche had only one problem during the six years of ownership, but it was the rear main seal which is a HUGE deal (like $3k to fix). Plus it wasn't a daily driver, and most people's aren't, so if it had a problem I generally didn't find out for a week or two. I've found word-of-mouth and actual performance of the MINI to get great. JDP is not always where to look when researching anyway, I came here to NAM and got the information first hand.
Old Jun 6, 2008 | 05:30 AM
  #62
jggimi's Avatar
jggimi
Originally Posted by lhoboy
Anyone know what gen MINI was included in this study? ...
2008 R56s.
Here's a link to a summary breakdown of eight quality categories: four in mechanical, four in design:
http://www.jdpower.com/autos/ratings...ings-by-brand/
You can also click on category titles to get additional descriptions of each category.
Old Jun 6, 2008 | 05:39 AM
  #63
nomo1982's Avatar
nomo1982
Isuzu has withdrawn from the US market. For several years the only 2 models sold have been rebadged GM SUVs/trucks.
Old Jun 6, 2008 | 05:54 AM
  #64
gokartride's Avatar
gokartride
Works for me!!
Old Jun 6, 2008 | 09:07 AM
  #65
DanQ's Avatar
DanQ
This is not good news. I don't blame the survey. I don't blame the owners for filling out the survey. The blame lies with the mfgr. and the quality of the product delivered to customers.
As a couple of people mentioned, most mfgrs take the survey seriously and try to improve the initial quality of their products. MINI needs to improve.
Here are more detailed survey results for the 08 Mini. It separates "design" issues from "mechancial" issues. It sure doesn't look llike the MINI is ranked low because of cupholder design! Its low for MANY measures.. This isn't JDpowers opinion, its the opinion of fellow MINI owners...
http://www.jdpower.com/autos/MINI/Co...chback/ratings
Old Jun 6, 2008 | 12:55 PM
  #66
Gil-galad's Avatar
Gil-galad
I did not know that...and of course, since JDP only appears to be looking at the most recent (i.e., 2008) model year, their assessment of insufficient data for Isuzu makes sense.
Interesting that the R56 Powertrain Quality Mechanical/Design got the highest marks among the scores. I guess the cold start chatter issue--though potentially the most serious--probably doesn't show up much in the survey since it only includes items reported within the first 90 days. It's the nit-picky stuff (melting scoops, weeping washers, sunroof noise, getting used to the turn signal control, etc.) that get early attention and thus, reported in the survey.
Old Jun 6, 2008 | 01:03 PM
  #67
Ed.A's Avatar
Ed.A
I'm really sorry that this will be my first post. I call BS on this survey for a few simple reasons. Audi, Jaguar ? Nuff said.
Old Jun 6, 2008 | 04:35 PM
  #68
kbleicher's Avatar
kbleicher
The fact that JD Powers still doesn't have a picture for the Clubman, they call it a "wagon", and they said "no changes for 2008" pretty much sums up my opinion of their survey
Old Jun 6, 2008 | 05:33 PM
  #69
redhornet's Avatar
redhornet
Well I've had a re-think on this subject (based on recent events) and I've come to the following conclusion: It doesn't matter WHY the Mini is ranked so low, what BMW MUST do now is make the necessary improvements as quickly as possible to get the numbers up as high as possible for Mini. BMW boasts about how they have superior product quality because they are their own company, well they now need to back their advertising with real world results.
If I continue to have issues/problems with my 07 Cooper throughout the rest of the year, I'll sell it in a heartbeat and never buy one again.
Face it folks, there plenty of fun cars to drive out there, and many of them have much better reliability ratings...
Old Jun 6, 2008 | 05:39 PM
  #70
sikamini's Avatar
sikamini
I guess after reading those descriptions when I go pick up my MINI in September I should bring along a bucket.
I gathered from JDP that intuitive, simplified controls and functions make for a better car. Personally I have found many computer programs which claim to be intuitive anything but intuitive for me. Following that thought - if others find the MINI too complex to handle maybe it will be just right for me. I am not judging anyone, but you can not design anything a car, a house or a kitchen appliance which is simple for all. Sometimes what is simple to one is complex to another and visa versa. I would like to see some perspective in these studies - we are not all wired the same and that's a good thing.
The descriptives at JDP tell me very little unless I see the actual questions. Maybe one of the MINI owners who took part in this survey could post the questions.
Old Jun 6, 2008 | 05:55 PM
  #71
lhoboy's Avatar
lhoboy
Whatever the other issues are, you have to admit the turnsignals are a real PITA. Turn signals have worked the same way on all cars (no, I'm not counting some french abominations)for close to a century -- until the R56. Takes awhile to adjust to them. And it's impossible to get used to them if you drive other cars on a regular basis (like an R53). Might as well put the turn signals on the other side of the steering column like they were on the classic.
(OK, time to take my medicine again )
Old Jun 6, 2008 | 06:53 PM
  #72
MotorMouth's Avatar
MotorMouth
MINI came out with a statement about the survery.
It said over 70% of the people surveyed had bought a convertible and the number one compaint was - cupholders too small.
Old Jun 6, 2008 | 07:09 PM
  #73
mellowmcs's Avatar
mellowmcs
I'm very sure that the E90 BMW had them before the MINI R56
Old Jun 6, 2008 | 07:14 PM
  #74
oneway's Avatar
oneway
I'm one of the people who filled out the JD Power survey and sorry for being honest. I love the way my car drives and handles but the car is poorly engineered and poorly built. Here's a list of defects I had in the first two months that made it into my response to JD Power:
1 Engine loose on mounts (fixed after three months)
2 Whistling on drivers side window (learned to live with it)
3 Whistling on passenger side window (learned to live with it)
4 Malfunctioning hatch release (possibly related to loose hatch trim panel)
5 Internal hatch panel detached when closing trunk (not repaired)
6 Nav system disk (backordered for three months)
7 Voice activation not installed (took two months to fix)
8 Bluetooth not installed (took one month to fix)
9 Sunroof not functional, would not open (replaced, still doesn't work right)
10 Right stereo speaker intermittent (not repaired)
11 Rattle and resonance from dash
12 Rattle from somewhere behind the driver, unable to locate it.
Are any of these acceptable issues? Was I expecting too much in a new car? I brought it in for service ten times in the first five months and was off the road for two weeks in total. Had to ride a bicycle to work a couple of times thanks to quality BMW service that thinks loaners are only offered on a first come first serve basis.
Since filling out the survey the car has failed to start when cold. it left me stranded once due to an improper repair causing a power drain. I had to have it detailed after the sunroof was replaced to remove the greasy black fingerprints on the headliner.
I filled out a JD Power survey with my last car, a 2002 Acura RSX, first year of production for that one too. I listed zero defects, great car but boring to drive compared to the Mini. The Mini has it's charms I know, but build quality and competent engineering are not among them.
When people ask me how I like my car I give them an honest response, if one in ten of these people are considering a purchase their shoddy workmanship on my vehicle likely cost Mini hundreds of thousands of dollars in lost sales. Sorry if it hurts your resale but lying for financial gain is unethical; at least to me, but it seems to be the way BMW does business.
Listening to a service tech tell me BMW will install voice recognition at no charge because they are so nice and care about their customers sent me into rage when I already paid for it. Being told the loose bolts on the engine and suspension are a feature not a fault borders on insane; so what if it makes it easier to work on? If the bolts were properly tightened they wouldn't need to work on it and the car wouldn't be a rolling deathtrap. I guess in Europe it keeps people employed fixing them, but I don't want a car that has some weird socialist agenda, I want a reliable well made car.
Mini and BMW as a whole needs to get their act together. The results of the survey show I am clearly not alone in my experience.
Old Jun 6, 2008 | 07:20 PM
  #75
gokartride's Avatar
gokartride
Not a problem, of course....although the report is mystifying to those of us whose MINIs were rock solid from day one.
