R56 Gas Tank Arrow Pointing The Wrong Way?
Old Apr 21, 2008 | 09:47 PM
Cooptime's Avatar
Cooptime
Ok, just a minor annoyance, but I think the arrow telling you which side the gas tank is on is pointing the wrong way? I assume the arrow next to the gas-pump icon by the readout on the tachometer should tell you which side the gas tank is on...right? Well, it points to the right side of the car, but everyone knows its on the left. What gives? I know my BMWs have this same feature, but their tanks actually are on the right. Did BMW mess up and just carry over the software without fixing this? Or, does the arrow stand for something else of which I am unaware?
Thanks!
Old Apr 21, 2008 | 10:19 PM
ghosthound's Avatar
ghosthound
there is an arrow?
mauberley's Avatar
mauberley
Maybe that's the "distance to empty" readout on the tach?
Old Apr 21, 2008 | 10:22 PM
Sowellman's Avatar
Sowellman
I think you're spending way too much time analyzing things.
Old Apr 21, 2008 | 11:09 PM
rippymcs's Avatar
rippymcs
I think that's what he's talking about, too.
Some of the graphics/icons on the MINI is not exactly intuitive, but that could just be an European thing.
Old Apr 22, 2008 | 05:45 AM
D-Unit's Avatar
D-Unit
it just points to the number of miles you have left. its just a coincidence that some bmws have the tank on the right side. it is safe to assume that you would know what side your gas tank is on. or is it?
Old Apr 22, 2008 | 05:57 AM
leicaguy's Avatar
leicaguy
Or is it telling you to pull up to the right side of the pump?
Old Apr 22, 2008 | 06:00 AM
Darkness's Avatar
Darkness
For the longest time I thought the low tire monitor was a plumbers butt
Old Apr 22, 2008 | 06:01 AM
purplefenderman's Avatar
purplefenderman
hold on a sec... do you have a pic of this?
Old Apr 22, 2008 | 06:38 AM
kavatski's Avatar
kavatski
It's an arrow pointing to a gas pump. As pointed out above, this is the symbol for "distance to empty" and is not meant to be an indication of which side the gas door is on.
Old Apr 22, 2008 | 07:10 AM
cristo's Avatar
cristo
Alliance Member
I saw a blurb a few months ago on aol's welcome menu that said the pump
handle on the gas gauge icon tells you which side your gas cap's on.
Went out and found it to be untrue for my R50 and my wife's VW.
Another urban legend bites the dust.
http://www.hoax-slayer.com/fuel-tank...n-secret.shtml
Old Apr 22, 2008 | 07:38 AM
condor27596's Avatar
condor27596
I heard that Germans put the gas filler on the
right side because if you run out of gas, you would
then be filling it beside the road in the safety of
the ditch or median thing instead of standing more
in the line of the oncomming traffic.
Maybe the mini is on the left side because they are
British more or less. (?)
Anybody else heard this?
Old Apr 22, 2008 | 08:13 AM
Loony2N's Avatar
Loony2N
All my Benz's had them on the right, but I don't know if that is the reason. They also had the arrow next to the gas pump symbol pointing toward the right, which was to tell you which side the filler was on. I don't recall looking on the Mini.
Old Apr 22, 2008 | 08:22 AM
Auto_Pilot's Avatar
Auto_Pilot
Let's see the arrow points to the left side of the car, but the gasoline icon has the gas nozzle on the right side...so iwas like
Maybe the overseas cars have the tank on the righ hand side???
Old Apr 22, 2008 | 08:31 AM
Squirlz's Avatar
Squirlz
No, it's because the freeway gas stops are set up so you can only fill from the right.
Old Apr 22, 2008 | 12:22 PM
Wrigster's Avatar
Wrigster
Actually, I recall being told that car manufacturers had standardized the way to document which side the filler cap is on the car. They use the handle on the gas tank symbol to indicate which side. I'm not sure if someone was pulling my leg or not, but it seemed to be accurate.... except for the Mini, which has the handle on the right, not the left.
Old Apr 22, 2008 | 12:24 PM
Loony2N's Avatar
Loony2N
Ummm, we had an American vehicle in Germany, with left hand gas filler and we had no problem getting gas on or off the autobahns.
Old Apr 22, 2008 | 01:16 PM
Squirlz's Avatar
Squirlz
Glad that worked out for you. I'm just supplying the answer to the question.
Old Apr 22, 2008 | 01:19 PM
Loony2N's Avatar
Loony2N
My point is, your answer isn't correct. At least, it wasn't in the 80's in Germany and certainly isn't here now.
Old Apr 22, 2008 | 01:25 PM
TheBigNewt's Avatar
TheBigNewt
Every rental car I've used has an arrow on the gas guage itself that points to the side of the filler. The Mini doesn't have one on its guage. Maybe you can't rent Minis?
Old Apr 22, 2008 | 01:30 PM
Squirlz's Avatar
Squirlz
Lynn, there are no absolutes. But there are an abundance of gas stops where you can only fill on the right. Enough to make it a reasonable standard to put the fillers there. If I had been speculating I would have said "I think". Good day.
agranger's Avatar
agranger
I'm almost positive that mine has an arrow pointing to the left side where the filler is. My wife's Caddy has an arrow pointing to the right, where the filler is on her car. I've used the arrow on several rental cars to pull up to the pumps properly as well...
It's not frorm a MINI, but this pic from the hoax-slayer link, above, shows the little arrow indicating that the filler neck is on the left side of the car...
Old Apr 22, 2008 | 01:38 PM
agranger's Avatar
agranger
Looks like the guys at www.outmotoring.com have the arrow as well... (see the bottom right-hand pic)
Old Apr 22, 2008 | 01:45 PM
agranger's Avatar
agranger
And the guys at Cockpit Specialties have the arrow in a slightly different place... actually ON the lower portion of the pump icon
Old Apr 22, 2008 | 01:48 PM
Calaway16's Avatar
Calaway16
If you have an S just look in the rear view mirror. Can't miss the big chrome thing.
