R56 Motive Power Bleeder
Old Mar 28, 2008 | 09:27 AM
scottab36's Avatar
scottab36
Has anyone ever used a motive power bleader on the MINI? I have one and test fit the cap to the brake reservoir and it fit fine. Also does anyone know what the bleed sequence for the R56 MCS would be?
Old Mar 28, 2008 | 09:47 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I've used one on my R52 and it worked great.
Old Mar 28, 2008 | 10:56 AM
pdflint's Avatar
pdflint
I've used one on my R53 to flush the hydraulic system when I replaced pads & rotors. It worked very well. Bleed sequence is RR, LR, RF, LF, clutch master cylinder.
Old Mar 29, 2008 | 12:17 PM
smackboy1's Avatar
smackboy1
On the R56, does the brake and clutch share the same hydraulic system? Where is the bleeder valve for the clutch line located?
Old Mar 29, 2008 | 12:22 PM
scottab36's Avatar
scottab36
I will have to look under the hood to check that out!
Old Mar 29, 2008 | 12:57 PM
ashboomstick's Avatar
ashboomstick
I used mine on Wed. to completely flush my stock fluid with Super Blue after putting SS lines on my R56 .
Had no problems whatsoever, pressed the tank up to 10 psig and that was good to do all 4 corners. Be careful though, if you loosen up the bleed screw a little too much some air seems to leak through the threads and get entrained in the fluid flow. This makes it look like you've still got air in the lines. Seems like fluid should come out of the threads but it didn't. If you wiggle the bleed screw a little bit you can see how it affects the bubbles.
Old Mar 29, 2008 | 03:24 PM
scottab36's Avatar
scottab36
SS Lines
Where did you get the SS lines from?
Old Mar 29, 2008 | 06:11 PM
ashboomstick
Chad and Tori at Detroit Tuned. Can't recommend them enough.
Old Apr 13, 2008 | 11:12 AM
Ryephile's Avatar
Ryephile
This sequence sounds good! The reservoir is in the front left of the car, so RR, LR, RF, LF, clutch makes sense to me. The Motive bleeder rocks; it makes bleeding/flushing the system easy!
Old Feb 1, 2015 | 01:44 PM
'10JCW's Avatar
'10JCW
sorry to revive an old thread, but which model works for the R53
Looking at this one:
Amazon.com: Motive Products Power Bleeder Adapters to fit most European car models: Automotive Amazon.com: Motive Products Power Bleeder Adapters to fit most European car models: Automotive
twriter
Oct 2, 2015 03:14 PM
paul7878
Sep 14, 2015 07:44 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 9, 2015 01:37 PM
PelicanParts.com
Accessory Products
Sep 3, 2015 08:54 AM
Ntety
Sep 2, 2015 08:39 PM
