R56 Do People Miss Having a Temperature Gauge?
Old Feb 23, 2008 | 02:08 AM
umberto's Avatar
umberto
My '04 MC has a temperature gauge, but I believe the 2007,2008 does not....do people miss having a gauge? I know I could get used to the car warmimg up without me being able to follow its progress but I do glance at the temp gauge from time to time on long highway trips to make sure there is no overheating issues (never any problems with overheating so far but had a Neon with a lousy radiator that would overheat....I remember one long uncomfortable trip where on a 95 degree day I had to drive with the heat on full blast to vent heat from the engine to prevent oveeheating). Do you feel comfortable having just a light to let you know that the car is now, or almost, in an overheating situation?
Old Feb 23, 2008 | 04:04 AM
NashvilleMiniStan's Avatar
NashvilleMiniStan
Yes you are right my 07 does not have one. Yes it would be nice.
Old Feb 23, 2008 | 04:27 AM
muladesigns1's Avatar
muladesigns1
If you think about it, most people only look at there speedo and gas guage.
Personally, the more guages the better! I regularly check all my guages when I drive. and add those which the manufacturer was not inclined to offer me.
Old Feb 23, 2008 | 05:15 AM
umberto's Avatar
umberto
are there any stock-looking aftermarket temp gauges for the R56 MINI??
Old Feb 23, 2008 | 05:42 AM
tdm156's Avatar
tdm156
Ruling the curves
I miss the temp gauge in our 08 for sure....an idiot light just cant be enough can it? My wife drives the 08 for a daily driver and I am not worried as it will never affect her at all....but for me I agree more gauges
Old Feb 23, 2008 | 05:46 AM
gokartride's Avatar
gokartride
Does it?? Actually I believe it does not...not a true gauge...and some folks found this out the hard way. It is (sadly) little more than a dummy light w/ a needle, so don't treat it otherwise. That said, R56 has a duel stage light (yellow and red) and knowing what those stages inticate would be important as it is relaying some information. That said...yes, I really would like a real temp display (maybe even not a gauge), and I would want them to place it with the brilliant OBC readouts which are now available in the R56 speedo display. There's all kinds of info there...I'd love to see a temp readout (and maybe a few other things) there as well. That would keep the interior tidy w/o the need to hang gauges or other devices all over the place...I hate clutter. With the current setup you can see a variety of parameters at once, or select one to monitor....and since the buttons are at a higher location (up in the speedo) you can flip between readings very easily. I love that feature and use ot all the time. Perfect spot for a temp readout.
I freaked when I was flipping through that section on an '08 MINI and found items renamed and additional information available...it really illustrated that that section can and is being modified and updated!!!
Old Feb 23, 2008 | 06:47 AM
mistro's Avatar
mistro
And that's the perfect reson to add Scan Gauge http://www.scangauge.com/
or Brockway Engineering
http://www.brockwayengineering.com/
less popular but perhaps a bit more advanced... both work with the older MC, new generation, not sure, But HIGHLY recommended and install is a breeze
Old Feb 23, 2008 | 07:06 AM
slag1911's Avatar
slag1911
My 2006 R53 had a fully functional gauge...
And having a turbo charged automobile without a temperature gauge is actually quite pathetic when you think about it... what was BMW thinking?
Old Feb 23, 2008 | 07:08 AM
checkercoop's Avatar
checkercoop
Yeah i plan on getting a scan gauge soon...i think it will look kinda stock in a way since it has an orange backlight so it can match to stock orange gauges
Old Feb 23, 2008 | 08:01 AM
JohnnyF's Avatar
JohnnyF
It sounds like that "gauge" worked out really well for more than a few people; here's but one example:
Originally Posted by lotsie
Ah yes the famous R50/R53 temp. gauge.
Useful as the car warms up to normal operating temp. Useless in an overheating situation.
My 03 MC overheated because of a block heater leaking, which heats coolant in the engines water jacket. It is a MINI part, that was installed by the dealer. I was on the highway, a few minutes from home when it let go, the gauge went from normal to the top of the gauge in less than 10 seconds, then the "idiot" light came on and it started chiming at me. From what I have read since about it, thats how it works, works well up to normal temp. then does not respond well until the the engine is overheating So really just a glorified "idiot" light.
Mark
Old Feb 23, 2008 | 08:06 AM
Ambrosia's Avatar
Ambrosia
yes i miss having one....i was surprised at first when i realized there wasn't one. i can always go the aftermarket gauge route but i don't think i should have to in the first place....
Old Feb 23, 2008 | 08:11 AM
Minidrivr's Avatar
Minidrivr
I miss the gauge as well. There are some options out there for aftermarket, but none that really match the stock gauges.
The idea of adding it to the OBC display is great. The car already has the sensor since water temp is visible through the OBDII connection.
Old Feb 23, 2008 | 08:53 AM
rhawth99's Avatar
rhawth99
I have a 'real' temperature gauge, it's called the chrono package and includes a real oil pressure and oil temperature gauge too. I was hoping that BMW would offer something like this for the Clubman.
Old Feb 23, 2008 | 10:32 AM
Robin Casady's Avatar
Robin Casady
I have the ScanGaugeII and like it. Coolant temp is typically 220 to 222 F.
Old Feb 23, 2008 | 10:55 AM
AT T 2D's Avatar
AT T 2D
I have Alta boost and temperture gauges on order, can't wait to get them in.
Old Feb 23, 2008 | 11:04 AM
gokartride's Avatar
gokartride
That is the state-of-the art solution, imo, in that it is so flexible and you don't need half a dozen gauges hanging *****-nilly all over the place. Now, wouldn't it be cool (I think so) if that functionality was integrated into the R56 speedo readout? Just a dream...
Old Feb 23, 2008 | 11:44 AM
emtrey's Avatar
emtrey
I think it is needed in this car.( especially w/ turbo)..wake up MINI
Old Feb 23, 2008 | 12:14 PM
muladesigns1
actaully I think all guages should be in all cars. if we can only get more "auto enthusiasts to own and demand " it.
Old Feb 23, 2008 | 12:17 PM
Msteadman's Avatar
Msteadman
The MINI is my first car, so I'm not used to having one per say, but I do miss a temperature gauge nonetheless... Especially now that I've gotten into mods and am learning the technicals aspects of our wonderful motor. Also there's been at least one instance in which I'm pretty sure my temperature was a bit high, but the 'idiot light' wasn't on... Would have spared me a ton of stress having a simple read out of some sort.
I'll likely add the ALTA coolant and boost gauges eventually. Would just prefer something closer to the OEM style.
Old Feb 23, 2008 | 12:53 PM
greengobln's Avatar
greengobln
i believe it does. my 04 S has risen to 3/4 a few times and both times there was an actual issue i discovered before it was too late. the first time i needed a thermostat and the second time the dealership did my flush and forgot to add enough radiator fluid. therefore i believe it does.
BriGuy
Old Feb 23, 2008 | 12:59 PM
MrVvrroomm's Avatar
MrVvrroomm
Don't miss it, don't need it.
Old Feb 23, 2008 | 01:13 PM
umberto's Avatar
umberto
sounds like greengobln would disagree with Mrvvrooomm
Old Feb 23, 2008 | 01:26 PM
AstroBlackS's Avatar
AstroBlackS
Temp Guage = good info to know. IMHO
I want an A/F guage as well.
Old Feb 23, 2008 | 01:48 PM
Minidrivr's Avatar
Minidrivr
The lack of temp gauge is the only reason I'm considering adding gauges. I like the stock look without the gauges but feel temp is too important. You need to know when temperature is increasing, not once it's gotten too high. Does the Mini's idiot light warn you early when the temp is increasing or just when the car is too hot?
Old Feb 23, 2008 | 01:51 PM
muladesigns1
+1 why would you not want to know whats going on in something that you rely on as much as a vehicle
oh well guess youll see things differently while on the side of the road with steam blasting out from under the hood. meanwhile you could have been parked at a nice convienient location waiting for a "slightly" hot motor to cool for you to limp it to its needed destination.
