R56 So do you all use Premium gas ALL the time?
Old Jan 19, 2008 | 05:20 AM
Littlesha's Avatar
Littlesha
I have some people telling me to go Premium all the time, and others who tell me to alternate between Mid and Premium. What do you guys usually stick to?
Sharon
Old Jan 19, 2008 | 05:23 AM
BlimeyCabrio's Avatar
BlimeyCabrio
100% 93octane, for almost 27,000 miles so far. I drive HARD with some wide open throttle and high RPMs every tank - so I might actually be getting some benefit from the higher knock-resistance. Folks who drive more conservatively would probably do fine with 89octane much of the time...
Old Jan 19, 2008 | 05:27 AM
itburns's Avatar
itburns
All the time.
glangford's Avatar
glangford
Always Premium. I do drive conservatively but don't seem any reason to depart from the manufacturer's recommendation. At over $3 per gallon, 10 cents more a gallon seems insignificant.
I have heard that for some MCs in cold climates that there may be some advantage to a lower mid octane fuel during the winter.
Old Jan 19, 2008 | 05:37 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Sharon
Cooper?
or
Cooper S?
Does it get cold where you live?
Old Jan 19, 2008 | 05:39 AM
Li'l Red's Rider's Avatar
Li'l Red's Rider
Premium, always.
Old Jan 19, 2008 | 05:45 AM
jonnieoh's Avatar
jonnieoh
ALWAYS premium.
Since I use my credit card with every fill-up, (to get reward points), I therefore don't even look at the total I spend every time. That helps make it much less painful!
But seriously, I figure there are many good reasons that MINI specifies the use of 91 octane or higher fuel in their cars. They're the manufacturer, so I must assume they know what's best for my car.
My car is too important to me to skimp on octane, so I only use premium.
Old Jan 19, 2008 | 05:50 AM
tdm156's Avatar
tdm156
Ruling the curves
Always use premium. For the few cents per tank that it cost its more than worth it to me and to my MINI. Only the best!
Old Jan 19, 2008 | 06:13 AM
rwk317's Avatar
rwk317
Chevron 94 everytime .......... so far.
Old Jan 19, 2008 | 06:22 AM
9000RPMan's Avatar
9000RPMan
Shell VPower all of the time.
Old Jan 19, 2008 | 06:28 AM
gokartride's Avatar
gokartride
Nothing but.
Old Jan 19, 2008 | 06:38 AM
buzzsaw's Avatar
buzzsaw
Since day one. Haven't yet found a reason to deviate from the ops manual. Besides the delta in cost is insignificant.
Old Jan 19, 2008 | 06:42 AM
sailorliz23's Avatar
sailorliz23
yea we always use premium on both minis. same thing everyone else says the price difference is about 10 cents here so its not going to kill me and id rather stick to what we should put in it. but it doesnt get cold here so it may be different for you.
Old Jan 19, 2008 | 06:44 AM
davisflyer's Avatar
davisflyer
Shell V-Power 93 octane all the time. Really, it's about 1 dollar difference per fill up. I can handle an extra buck since it's the recommended grade.
Old Jan 19, 2008 | 06:55 AM
andyde's Avatar
andyde
...all the time. Chevron or Shell...
Old Jan 19, 2008 | 06:57 AM
tpetro33's Avatar
tpetro33
Shell V Power...every time...all the time.....
Old Jan 19, 2008 | 07:08 AM
mattbren
I use 87... The manual recommends 91 but says 87 is OK also. I never get any knocking, and according to the manual, "This has no effect on the engine life."
Old Jan 19, 2008 | 07:46 AM
soul embrace's Avatar
soul embrace
all the time, if you look at it it's not that much more. plus i read that it does better on gas mileage with the premium. if this is true then if you use anything less than premium you end up paying more for gas since you will be filling up sooner. i've been getting my gas at walmart's gas station and i haven't had any problems plus i get 3 cents per gallon off using their gas card.
Old Jan 19, 2008 | 08:03 AM
TheBigNewt's Avatar
TheBigNewt
91 Shell everytime (max we can get in AZ). I never had the guts to use 87.
Old Jan 19, 2008 | 08:13 AM
Motodude's Avatar
Motodude
Maybe a better question is: Has anyone tried running a lower grade gasoline and checked their mileage to see how it compares with premium?
The engine has a knock sensor which will retard the ignition timing to protect against pre-detonation. However, this lowers efficiency and power, which may affect mileage, depending upon how often it occurs. How often it occurs depends on your driving demands, air temperature & pressure.
The manufacturer specifies premium because it covers them under all conditions. You should only run the minimum octane which works for you, otherwise, you're wasting money and energy.
Old Jan 19, 2008 | 08:18 AM
Chuck W.'s Avatar
Chuck W.
91 octane in CA too,,, the highest we can get.
Old Jan 19, 2008 | 09:09 AM
r56mini's Avatar
r56mini
$0.10 difference/gal x 12 gal/fill x 1 fill/370 miles x 10000 miles/ year
=$32 difference /year.
Is that right??
Old Jan 19, 2008 | 09:19 AM
jggimi's Avatar
jggimi
Our choices in this area are 87-89-93. 93 always. Having had one fuel-related problem from one retailer, I also restrict my purchases to Top Tier suppliers. In this area, that's Shell only.
Old Jan 19, 2008 | 09:20 AM
LOP's Avatar
LOP
We always use the highest grade available...always!
Old Jan 19, 2008 | 10:13 AM
MINIdave's Avatar
MINIdave
FWIW, I found my '03 starts and runs better in this really cold weather if I use regular. Have any of you 2 gen cars experienced this?
No difference in the mileage that I can tell, it always sucks this time of year! I'm only getting 23 - 24 mpg and most of my driving is hiway. I usually get around 28 -30........
I'm going to get it dyno tuned by Jan next month, so I'll get premium back in it a couple of weeks before to get it back up to max power..........
