R56 DIY Oil Change 2007 MINI Coupe with Pics
Old Jan 14, 2008 | 07:43 PM
  #26
Robin Casady's Avatar
Robin Casady
Originally Posted by johne123
I'm sure someone else will chime in, but Mobile 1 5w30 doesn't meet the same specs as the Mini OE oil. Yeah, sure it's synthetic, the right grade, and according to the manual, meets the minimum API spec, but it's not an ACEA A3/B3 oil. If it has to be Mobil 1 looks like 0w40 meets the ACEA spec.
Originally Posted by J A Blazer
Is this true?
Yes, Mobil 1 5W-30 has a different "High temperature / High shear rate viscosity" than the MINI packaged Castrol you get at the dealer. In short, Mobil 1 5W-30 isn't as suited to high performance engines as the MINI oil. The other difference has to do with how long it holds up, but that doesn't matter much if you are changing oil frequently.
Originally Posted by ubdylan
Mobil1 is fine if you are doing frequent oil changes but it does not meet the true specs set forth by MINI/BMW. If you are changing oil every 5,000 miles it should be fine. I asked a tech at the dealer and he stated that is what he uses in his ride, but changes are per the 5,000 interval. The MINI oil supposedly can go 20,000+ miles according to the d@mn computer in our cars, and the service writers at the dealership who tell you you can't come in for an oil change until it jives with the OBC and/or 12 months has passed. But if you believe that, I have a some real estate I can sell you.
Frequency of oil change is just half the issue. The other half is what it does at engine temps. So, changing the oil frequently doesn't really make up for the difference.
What you want to look for on a bottle of oil is ACEA A3/B3 and BMW LL-01.
Old Jan 14, 2008 | 07:56 PM
  #27
Robin Casady
Originally Posted by Chuck W.
Great post. The Mini will hit 1,000 miles this week so it will get it first change next weekend.... then every 5,000 miles there after. 10w-40 Mobil One - the regular stuff.
I hope you meant Mobil 1 0W-40 because 10W-40 doesn't even come close to what you should use.
Old Jan 14, 2008 | 08:04 PM
  #28
Robin Casady
Here is another thread with detailed instructions and photos. There have been some corrections and useful hints further in the thread, so best to at least scan all of it.
https://www.northamericanmotoring.co...d.php?t=101513
Old Jan 14, 2008 | 08:56 PM
  #29
daffodildeb's Avatar
daffodildeb
Here ya go:
https://www.northamericanmotoring.co...specifications
Old Feb 3, 2008 | 06:36 PM
  #30
grantworld's Avatar
grantworld
Thanks, Giancola
Same story here in regards to dealer not changing oil until computer says it needs changed. In this case that would be 22,500 miles before the first change! Dealer/BMW did not seem to care. Decided to just do myself, googled and found posting from Giancola. While I have an MCS, Giancola's very nicely done article was a tremendous help. Certainly easier than my 2002 MC. Incidently, I use Castrol on both 2002 MC (with 97,000 miles) and new MCS and change at 15,000. Might as well take advantage of the synthetic oil.
Old Feb 3, 2008 | 06:55 PM
  #31
Robin Casady
Not all synthetic oils are rated for 15,000 miles, and not all are adequate for the R56 MINI. It should have ACEA A3, and BMW LL-01 (or higher) ratings on the bottle. Not a lot of USA Castrol does.
Old Feb 3, 2008 | 09:18 PM
  #32
Minidrivr's Avatar
Minidrivr
Originally Posted by glangford
I know on my MC you can actually remove the filter cap with an open end wrench it so easy to get to. The MCS is much harder, most remove the coolant reservoir and push it off to the side without undoing hose connections.
Well much harder is all relative. It's only 1 more bolt to move the coolant tank. Then you have all the room you do in a non-turbo.
Old Feb 3, 2008 | 11:37 PM
  #33
army scope jockey's Avatar
army scope jockey
Mobil 1 0w40 is the way to go. It meets BMW longlife requirements as well as Porsche and VW/AUDI. It is what I run in my Audi RS4. Fortunately, the px sells it here in Germany for around $6 a bottle. If bought on the German economy it would be about 20 euros (24 USD) a liter.
see link for more info
http://www.mobil.com/USA-English/Lub...il_1_0W-40.asp
Old Feb 3, 2008 | 11:55 PM
  #34
user 7082082's Avatar
user 7082082
Just a quick advise, the reason why the oil filter housing is at an angle like that even with the r53 is so a little oil stays in the filter compartmend. I do not recoment cleaning that oild oil with a rag. It will starve your motor on start up for a second so leave that "old oil" there and don't wipe it off.
Old Feb 5, 2008 | 02:42 PM
  #35
grantworld's Avatar
grantworld
Castrol
Full synthetic 5W-30 is approved by BMW.
Old Feb 5, 2008 | 05:09 PM
  #36
Kalk's Avatar
Kalk
did you reset the computer??? if did can you tell us how to reset the computer???? after oil change
Old Feb 5, 2008 | 05:15 PM
  #37
NashvilleMiniStan's Avatar
NashvilleMiniStan
Again thank you for taking the time and putting up pictures.
Old Feb 5, 2008 | 05:20 PM
  #38
Robin Casady
The MINI branded oil is ACEA A3/B3. Castrol 5W-30 is ACEA A1/A5 which has a lower viscosity at engine temp. The recommendations in the MINI manual are rather broad and can include a great variety of oil qualities. It is my belief that the engine was designed for ACEA A3.
Perhaps it doesn't matter for street driving. However, I'll stay with A3 quality.
Old Feb 5, 2008 | 07:37 PM
  #39
locogringo's Avatar
locogringo
I posted this on a new thread after reading this and other threads about oil. I am not sure if I should have posted it here, or if starting a new thread was the correct way to go.
https://www.northamericanmotoring.co...d.php?t=128096
Old Feb 6, 2008 | 06:11 AM
  #40
tjtull's Avatar
tjtull
Sorry if this has been asked before but I haven't changed my own oil in YEARS and I'll probably be doing it with my new Mini when I get it.
Where does everyone take their used oil and do you have to pay them to dispose of it? Also, how do you get it there (so it doesn't spill and screw up your car)?
Old Feb 6, 2008 | 06:57 AM
  #41
Minidrivr's Avatar
Minidrivr
Most auto parts places take used oil for free. My local garbage pickup takes used oil for free as well. They give you a container to put it in with a thick ziplock type bag for the filter. Check with your trash company or an auto parts chain. Some of the speedy lube type places take oil too.
Buy a drain pan with a pour spout like this. Lets me fill my recycling container without a funnel. Makes for no mess.
Or one like this if you are not going to pour it into another container for recycling.
Old Feb 6, 2008 | 07:10 AM
  #42
jw34's Avatar
jw34
This is totally off topic but after seeing your sig tjtull are you going to have a white russian when your car arrives?
Old Feb 6, 2008 | 07:37 AM
  #43
tjtull's Avatar
tjtull
You know it
Old Feb 6, 2008 | 07:38 AM
  #44
tjtull's Avatar
tjtull
Thanks for the advice. I'll check with my garbage collector. Nice looking drain pans too. I'll have to get some of those.
Old Feb 6, 2008 | 11:16 AM
  #45
ChubbyChecker's Avatar
ChubbyChecker
Originally Posted by giancola
Just did my first oil change at 6000 miles. It was much easier than I expected. Here are pics and some instructions I put together. Hope they are helpful. Pics are spread across thread.
Note on oil used: I used Mobil Fully Synthetic 5w30 this time, since I had some left over from previous car. This will be fine if changing every 5k or so. I plan on either using 0w40 or the Mobil 1 synthetic Extended Life Oil next go round at between 10-12k.
Note on tools: Sizes for the tools are T50 torx on the drain plug and 27mm or 11/16 for the oil filter housing.
Are you sure this shouldn't be 1-1/16" not 11/16"? 1-1/16" x 25.4 = 26.9875mm
Old Feb 6, 2008 | 02:24 PM
  #46
daffodildeb
We use 1 gallon milk containers--screw top only--and we do use a funnel with no problem. Been doing it since forever--60's?
Old Feb 6, 2008 | 03:26 PM
  #47
tjtull's Avatar
tjtull
Thanks, that's likely what I will do.
Old Feb 6, 2008 | 03:57 PM
  #48
Robin Casady
Do they still have gallon milk containers with screw tops? I thought they had all gone to the pop-off type.
Old Feb 6, 2008 | 05:31 PM
  #49
yarom's Avatar
yarom
Just to chime in on the recommended oil issue.
BMW recommends their own brand, which is Castrol stuff and absolutely simialr to Mobile 1.
I have run and seen others run Mobile1 (10-30) on several M3s, M5s and 7 series with no issues and with engines looking like new when opened up after 50 or 100K.
I would not hesitate to put Mobile1 in my MCS, well discounted from Costco, rather than pay the dealer for no reason...
Old Feb 6, 2008 | 06:16 PM
  #50
Robin Casady
Mobil 1 10W-30 is an ACEA A1/A5 oil recommended for GM cars, not approved by BMW. It is not the same as the BMW/MINI branded Castrol which is ACEA A3/B3, BMW LL-01.
