R56 DIY Oil Change 2007 MINI Coupe with Pics
After being unable to find the Mobil 1 Extended in the proper weight I decided to give Royal Purple a try for my last oil change. I have seen this brand recommended on numerous forums. I have never been one to get excited about oil brands but this oil did make a difference in my Mini. The engine is now much quieter and runs smoother. When initially starting the engine in the morning I no longer get that slight shake of the car when the engine 1st turns over. I also hear it improves mpg, but haven't had a chance to check that yet.
People , unless you've never tightened a screw before, putting a drain plug back in is not Rocket Science. You can still perform the Oil Change without a Torque Wrench.
A simple rule of thumb, if your hurting your wrist to insert a fastener or plug, your over tightening it.
I'm not trying to dismiss this out of hand, but certain actions don't require being **** over torque specs like an item such as the oil plug.
I prefer using a torque wrench, and getting it right. For those who don't use one, just a reminder that 22 ft-lbs is not a lot of torque. I would guess that most would over-tighten, rather than under-tighten. It's very easy to use too much torque, especially with a long-handled ratchet.(Give me a lever long enough and a fulcrum on which to place it, and I shall move the world. - Archimedes)
I had also never seen a drain plug with a Copper Crush Washer either and even at 22 ft/lb it seemed that I was tightening
a lot more than I would have expected.
If you went to finger tight (just contacting a new Copper Crush Washer) and then noted the number and fraction of turns to pull 22#,
you could just use that number in the future.
Oil Filter tightening had always been done by that method for other autos, but again, 18.5 ft/lb seemed tighter than I would have gone.
__________________________________________________ __________________________________________________ _____________
For those who turn wrenches a lot;
There was an old Pilot watching the old Aircraft A&I (Vince Fette) put his Aircraft together and asked "why no Torque Wrench?"
Vince put a torque wrench in the pilot's hand and said "Check'm" and went to lunch, the pilot found every bolt had been perfectly torqued to spec.
Well, I got through the oil change with no difficulty, thanks in large part to this thread and the fore-mentioned NAM Alliance article.
The one thing in my opinion that folks might want to watch for is how much new oil they put in. Someone said they called MINIUSA and were told that the '07 R56 takes 4.4 quarts and the article on NAM Alliance said 5. I went with ~4.4 and found it to be full. Will check it agaiin in the morning, but it seems all's well so far.
Not the case with mine melman8r; both the washer and O-ring were included. If in fact it is the case at your dealer, maybe you should shop elsewhere. I got two the other day just to have one on hand, but will use one of the vendors on NAM in the future.
BTW, my dealership is ALL over NAM, happens to be a sponsor. Thanks for your concern on where I shop.
Spot on
it was a first hand account, by an "old pilot" named True and I was young when he told me.Truman had a beautiful Luscombe 8F that he had bought brand new and flew for over twenty years, even had an RDF 'Loop' on the roof.
If he gave you a ride, first thing he wanted to do was demonstrate that he could still perform a loop.
There was a saying about "...no Old/Bold Pilots." but, glad to report that True did not expire in his airplane.
Doubt that you could over-torque the drain plug with an Allen Wrench before hurting your hand and would be surprised to see a MINI Shop Tech use a Torque Wrench on the drain plug, but that is where experience makes the difference. I was pleased to see that although he drew 5 quarts, he only added half of the last one.
Over Torque can be a danger, as proper torque actually stretches a bolt a specific distance and over torque= over stretched.
IIRC, there have been several reports on NAM of dealers torquing the drain plug so tight they couldn't get it off. Perhaps they use pneumatic tools. They are usually paid by the job -- not time -- so speed over craftsmanship is the name of the game at most car dealers.
When I did a change, I found that getting the filter housing to re-thread could be difficult, it was both easy to cross-thread, and required a good bit of pressure from a difficult angle to get the spring to compress enough to get the housing to catch the threads correcty. It was nerve racking until we called a friend who was a BMW mech. and he gave us the pressure secret.
Thanks giancola, for the great pics.
I'm going to do my first oil change at around 2k. I use the Mobile 1 Synthetic 5W30 in my other cars. However, after reading the other replies, I think I'll try to find the Mini recommended Castol at The auto parts store.
Oil Change in Gen 1 vs. Gen 2
Yes, my friend's MCS is a gen 1, so what you heard may be accurate; based on my sample of one change. I just ordered a gen 2, JCW, waiting for it to come in December. My prior mini was a Gen 1 but I sold at 3 years and didn't have to do any oil changes on my own.
More on my experience changing Gen1
I believe we did, I recall it was a firm fit, and we had to push quite firmly to make sure it was all the way in there. Again, only one experience, but, in my call to my nephew (the BMW mechanic) he immediately had the advice to give, saying it was a common complaint, that aligning the housing was difficult, and we had to be sure to give strong direct pressure to get it to catch properly in line, not cross thread, etc. Once I heard that, it was fine. Perhaps having experience on only traditional spin on filters, my feather touch used on a traditional filter was making a firm push to compress the housing feel like a lot of pressure.
The spring that keeps the filter up in the cannister is off-center, so that can tend to push the cannister 'crooked' on screw-in.
It is easy though, to keep it straight for that first turn, also worthwhile to pay attention to thread's 'start' point
and have thread engaged for that first turn.
