R56 What kind of coolant does the R56 take?
Old Nov 6, 2007 | 09:47 AM
flav's Avatar
flav
My R56 MCS with 10000 miles on it has low coolant. its about an inch below the MINIMUM line. i called the dealer and they said just put any type of coolant in there to top it off. this just didn't sound right to me. anybody know anything about this?
Old Nov 6, 2007 | 09:54 AM
Yucca Patrol's Avatar
Yucca Patrol
To top it off, just use some distilled water. A couple ounces of water won't affect anything. You should not use just any old kind of coolant.
Send your idiot dealer a bill for the $1 gallon of distilled water. Don't forget to add their standard hourly labor charge.
Old Nov 6, 2007 | 10:11 AM
flav's Avatar
flav
problem is i live in cleveland and it will be 0 degrees here in a month or so. can't adding water can increase the chance for freezing.
Old Nov 6, 2007 | 12:19 PM
djam43's Avatar
djam43
The closest answer I can give you is ZEREX G05 which is BMW approved. I would not recommend diluteing the present fluid with distilled water unless it was an emergency as it will alter your boiling/freezing/corrosion protection over time. I would recommend that you purchase and have MINI send you a gallon of their stuff since you live so far away.
Old Nov 6, 2007 | 12:51 PM
mikeg4572's Avatar
mikeg4572
Could be a good time to add some water wetter.
Old Nov 6, 2007 | 01:19 PM
COOP310's Avatar
COOP310
Is this not covered under the service warranty?
Old Nov 6, 2007 | 01:35 PM
Rastven's Avatar
Rastven
If you can get to dealer just buy a bottle of the MINI coolant. Easiest and safest thing rather than risking mixing coolants.
Old Nov 6, 2007 | 04:21 PM
sarafil's Avatar
sarafil
no, low fluids (oil, washer fluid, coolant, etc.) that need to be topped off between service visits are not covered, but good dealers would typically top it off at no charge if you stopped in.
now if we are talking about low fluids because of a leak or other malfunction, yes, that would be covered as would the repair.
danielbrookes_9
Oct 3, 2015 12:51 PM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
kwijmbo
Aug 5, 2015 09:00 PM
