R56 Bad manual transmission habit?
Old Oct 27, 2007 | 06:53 PM
mataku's Avatar
mataku
I have a habit of moving the shifter around left and right when I'm just sitting at a light. I basically just move it left and right relatively quickly like shaking it almost. I was just wondering if this is causing any wear on any parts that I should be worried about.
Old Oct 27, 2007 | 07:20 PM
gjhsu's Avatar
gjhsu
I really, REALLY doubt it is causing any unnecessary wear. I do that every once in a while just make sure I'm in neutral.
Old Oct 27, 2007 | 07:24 PM
korby's Avatar
korby
Yah I do it also .
Old Oct 27, 2007 | 07:34 PM
daffodildeb's Avatar
daffodildeb
You oughta see my Hubby do it in his Porsche 356. He rattles it back and forth to be SURE he's in neutral, and he's been doing it for 40 years without problems.
Old Oct 27, 2007 | 07:46 PM
gjhsu's Avatar
gjhsu
Now, leaving the clutch pressed in at a light might be considered a bad habit.... if only for the throwout bearing's sake.
Old Oct 28, 2007 | 06:18 AM
chili_red07's Avatar
chili_red07
^ I almost murdered my friend for doing that
Old Oct 28, 2007 | 06:53 AM
Gil-galad's Avatar
Gil-galad
I admit to having the "wiggle" habit too. Have had it for decades. Only while stopped, prior to putting it in 1st gear. I guess it just seems to give a little satisfying feedback on the side-to-side neutral throw range.
Old Oct 28, 2007 | 07:14 AM
Darkness's Avatar
Darkness
I do this all the time. My brother, who doesn't drive a manual, asked me what it does one time. I also like to row through all the gears sometimes, just to make sure they are still there.
Old Oct 28, 2007 | 08:10 AM
gjhsu's Avatar
gjhsu
It's irrational, but I do that too
Old Oct 28, 2007 | 09:34 AM
89AKurt's Avatar
89AKurt
I wouldn't call it a bad habit.
Always have done it because it's kinda embarassing when starting the car and it's in gear. Also helps me get oriented with the shift pattern limits.
Old Oct 28, 2007 | 09:39 AM
r56mini's Avatar
r56mini
Everybody does it. If you don't, it must be an automatic.
Old Oct 28, 2007 | 11:02 AM
mataku's Avatar
mataku
Thanks for all the responses. I was just worried it was bad for the car in some way. Figured moving parts = friction = wear
Old Oct 28, 2007 | 11:08 AM
roaduscarnivorous's Avatar
roaduscarnivorous
same reason i do it
keeping the clutch pressed during the light would be bad, imo
Old Oct 28, 2007 | 11:15 AM
MY4thMINI's Avatar
MY4thMINI
stop light
I have been driving stick for 22 years and have always put the car in first gear and hold one foot on the clutch and one foot on the brake, as i wait for the light to turn green.
Are you telling me I should be putting my car in neutral at every stop light?
Have I been driving stick wrong my entire life ?
fyi I have never burned out a clutch.
Old Oct 28, 2007 | 11:27 AM
ScottRiqui's Avatar
ScottRiqui
Well, sitting with the clutch depressed does put more stress on the clutch-actuation mechanism (cable-operated or hydraulic), as well as the throwout bearing, but it really depends on the particular car whether or not that's going to shorten the life of the clutch assembly over the normal lifetime of the clutch.
I usually shift into neutral and let the pedal out if I think I'm going to be stopped for more than a few seconds, though.
Old Oct 28, 2007 | 11:31 AM
daffodildeb
Then again, how long do you keep a car? I sold my 325i at 190,000 miles, with the original clutch. Hubby taught me to put it in neutral. He always told me a throw out bearing was a $10 part (yeah, I know--the good old days), but to get to it was hundreds.
Old Oct 28, 2007 | 12:00 PM
BritBoy's Avatar
BritBoy
When I was being taught to drive , (in England), the instructor always made me put the car in neutral at lights. Only when the light were about to change did I depress the clutch and engage first gear.
Old Oct 28, 2007 | 12:20 PM
MY4thMINI's Avatar
MY4thMINI
still shocked
Old Oct 28, 2007 | 12:44 PM
Newdl's Avatar
Newdl
great.....driving wrong for 2.5 years....time to unlearn the habbit lol
Old Oct 28, 2007 | 12:49 PM
Mr. D's Avatar
Mr. D
One point in time I had a little 73 Honda Civic, that once you put it in gear and then drove off the stick shift would bounce all over the place. The car would stay in the gear you put it in or just shifted to.
I would use it as an excuse to touch the girls knee in the passenger seat, it worked almost every time.....
Old Oct 28, 2007 | 12:52 PM
daffodildeb
Degenerate!
Old Oct 28, 2007 | 01:11 PM
MrVvrroomm's Avatar
MrVvrroomm
...lay off the caffeine for a day or so...lol
Old Oct 28, 2007 | 02:40 PM
r56mini's Avatar
r56mini
The consensus is nobody shakes it in an up and down motion at least.
Old Oct 28, 2007 | 02:52 PM
mataku's Avatar
mataku
I'll admit, my attention span isn't the greatest; but that's also one of the reasons I wanted manual. I had trouble keeping awake with an automatic.
Old Oct 28, 2007 | 03:12 PM
89AKurt's Avatar
89AKurt
Beats going to the gym.
Seriously, the best reason I have for this is: what happens if you get hit from behind by a drunk? You could have your feet get knocked off the pedals and the car would go out into the intersection. I know, kinda lame, but my dad told me that, after going through some sort of police training.
