R56 HELP Stripped XENON adjustment screw
Old Oct 10, 2007 | 06:09 PM
  #26
jascooper's Avatar
jascooper
I didn't see metal, but either method will work. unless you strip them both.
Old Oct 10, 2007 | 06:16 PM
  #27
rockridge's Avatar
rockridge
Originally Posted by kevinminict
LOL Yeah I stripped the hex part too I'm an idiot. I got a large flathead screwdriver in there to adjust which worked fine. BUT it would be nice to see if I can replace them I went to that website and its hard to tell I'll have to go down to the dealer and see.
Heres a pic of my stripped screw, yah i butchered the H&!! out of it.
I trick I have used in the past for stripped plastic, was to use a propane torch to heat up a narrow allen or torx wrench. Once good and hot, press the long end of the wrench slowly into the stripped plastic screw. It should melt into the plastic. Hold it steady, and let it cool. You now should have a way to unscrew the stripped screw. remember to wear gloves.
Old Oct 16, 2007 | 07:29 AM
  #28
rockridge's Avatar
rockridge
Kevin, Did you get a fix for this yet?
Old Oct 16, 2007 | 05:33 PM
  #29
r56mini's Avatar
r56mini
how about attaching a plastic piece to it with superglue? Something in the shape of a spring winder on toys.
Old Oct 16, 2007 | 05:37 PM
  #30
r56mini's Avatar
r56mini
seems like two tiny rocks would do the magic. place two tiny rocks in the stripped hole so that there is a thin space between the two tiny rocks. place a flat screw driver between the two tiny rocks and turn. The rocks should provide enough resistance, IMHO.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
patsum
26
May 29, 2021 06:29 PM
minimofo
Sep 30, 2015 12:26 AM
bbak11010
Sep 7, 2015 08:08 PM
bbak11010
Sep 7, 2015 08:03 PM
