R56 Union Jack roof Graphic doesn't fit on R56
Old Sep 1, 2007 | 08:55 AM
rockridge's Avatar
rockridge
Hi, I got word from my MA yesterday that my car was ready to be picked up, but they were unable to apply the Union Jack roof graphic due to spacing and the antenna.
This sounded odd, so I plan to contact another Mini dealer in Rhode Island to see if they are willing to install it, and work around the antenna.
Anyone else have problems getting a MINI "branded" graphic on the Roof?
Old Sep 1, 2007 | 09:34 AM
greylight's Avatar
greylight
Although I haven't seen it, I'd expect the roof graphic to be one large piece with no cutouts; the installer would just trim it to fit around the antenna.
gl
Old Sep 1, 2007 | 09:36 AM
MLPearson79's Avatar
MLPearson79
I would agree. I would think the antenna base would be removed and the graphic applied, and then the antenna base put back on with a small "punch" through the graphic for the wiring.
Old Sep 1, 2007 | 09:57 AM
CR&PW&JB's Avatar
CR&PW&JB
Yep, my roof graphic, albeit aftermarket, was one large sheet of vinyl. The installer cut it to fit like a glove. That includes around the antenna base. He just made a small hole, slid it down around the base, and then gradually cut it bigger to fit perfectly.
I suggest you buy the graphic and then find your own installer to do the job. Stay away from the dealership installers.
Old Sep 1, 2007 | 10:50 AM
soul embrace's Avatar
soul embrace
it will also be cheaper to get someone else to install it also
Old Sep 5, 2007 | 02:54 PM
rockridge's Avatar
rockridge
When I picked up my car at the dealer, I got the skinny on why they refused to install the "union jack" graphic.
To "properly" install the graphic, they need to remove the antenna. To remove the antenna, you need to drop the headliner in the car, and unbolt the antenna from the car. This is what my dealer refused to do, as they claimed it would never be the same again, and you could suffer with bumps and rattles that could not be found / fixed.
I confirmed this again today, when I contacted a local detailing shop to see if they would install the graphic. They replied the same way. To do it right, we need to drop the headliner, and they refused the work as well.
Anyone know a shop in the Mass / Rhode Island area that can do this work, or do I need to buy one from cooper flags, and try to install it myself?
rockridge
Old Sep 5, 2007 | 03:34 PM
djam43's Avatar
djam43
Yea, to drop the headliner ,it involves a bunch more disassembly including the a, b. c. pillar molding etc.
Old Sep 5, 2007 | 03:47 PM
valthun's Avatar
valthun
Which begs the question, why even offer the roof graphic now if no one will install it. Or why not install it at the factory before the headliner is installed. If you are ordering from the factory. I fell however that since it's a factory option from MINI that MINI should install it, and not refuse, then warrant the work from having to remove the headliner. Or perhaps MINI should come up with a way to work around the antenea.
Old Sep 5, 2007 | 03:57 PM
CR&PW&JB's Avatar
CR&PW&JB
Again, if the dealership can't install the graphic, find an independent installer to do it. A good one doesn't have to remove the antenna base to install the full roof graphic. Trust me, I've seen it done.
Old Sep 5, 2007 | 05:17 PM
rockridge's Avatar
rockridge
I am looking for such an individual, but so far have found no success.
Still looking....
Old Sep 5, 2007 | 05:29 PM
CR&PW&JB's Avatar
CR&PW&JB
I found one by asking the members of our local MINI club. Maybe you can try the same by using your local forum here on NAM.
Old Sep 5, 2007 | 06:06 PM
Tharkun's Avatar
Tharkun
rockridge
Try contacting a shop that does window tinting or clear bra installation, they should be able to do it, I had an estimate from a shop fo $50-100 depending if it was a full roof graphic or just a sun roof one.
Old Sep 6, 2007 | 03:20 AM
CR&PW&JB's Avatar
CR&PW&JB
^ Yep, I had estimates as low as $120 and as high as $400 for full roof w/sunroof. Ask around. Shop around.
Old Sep 6, 2007 | 08:34 AM
rockridge's Avatar
rockridge
I just received an estimate for $200. Trying to schedule an install before they change their minds.
Old Sep 6, 2007 | 12:25 PM
chiki143's Avatar
chiki143
Interesting, I had the MINI UJ graphic installed prior to taking delivery and they did it at the dealership. It is NOT one large piece of vinyl but individual pieces. The antenna is not even an issue at all.
Old Sep 11, 2007 | 05:08 AM
rockridge's Avatar
rockridge
Can you provide a close up photo of your roof?
Old Sep 11, 2007 | 10:24 AM
Madoc's Avatar
Madoc
http://motoringfile.com/howto/UJ%20Roof%20Decal.PDF
This is R53 specific - did the antenna change drastically on the R56?
Old Sep 11, 2007 | 10:48 AM
rockridge's Avatar
rockridge
Only that you can no longer twist the antenna base to remove it. Instructions look easy enough. I might just give it a-go myself.
Thanks Madoc!
Old Sep 11, 2007 | 02:26 PM
eliot's Avatar
eliot
Still looking....
Try ID Graphics in Easton,MA 800 327 8267
They did install on both my MINI's and I was very pleased with their work. Make sure you explain your problem. Ask for Sean
Old Sep 11, 2007 | 02:44 PM
aznqtboy984's Avatar
aznqtboy984
Was this at Mini of Peabody or Herb Chambers? I think the guy that does the decals at Herb is very incompetent.
Old Sep 11, 2007 | 06:06 PM
rockridge's Avatar
rockridge
It was at Herb Chambers. I also called Inskip in Rhode Island, and they too would not do the job with out dropping the headliner to remove the antenna. This makes installation a several hundred dollar gamble.
I am currently looking at ordering the flag from Morristown Mini with the 20% discount from Motoringfile.com, and installing it myself.
Old Sep 16, 2007 | 10:19 AM
chiki143's Avatar
chiki143
Here are a couple of photos of my roof. They just did a small rounded cut out from the end of the stripe so it fits around. Hope this helps.
Old Sep 16, 2007 | 06:19 PM
rockridge's Avatar
rockridge
Perfect!!
I thought about the mirror caps, but thought it might be too much. Looks great on your car!
The_Kid
Aug 16, 2015 11:13 AM
Aug 12, 2015 01:24 PM
CM2011RG
Aug 5, 2015 02:00 PM
