R56 Does Your Sunroof Rattle?
Old Aug 23, 2007 | 08:33 AM
mufflethis's Avatar
mufflethis
When I picked up my MINI I noticed that the roof rattled when I went over bumps, since there were a few other issues that needed addressing I took it in for service. After they fixed it it was perfectly quiet but it seems that the rattle is starting to come back. It's not as bad as it was before but you can definitely hear it especially on rougher roads.
So just wanted to see if anyone else has similar issues with the roof?
Old Aug 23, 2007 | 09:03 AM
rattmobbins's Avatar
rattmobbins
Nope. My MINI is (thankfully) rattle free.
Old Aug 23, 2007 | 09:06 AM
Loony2N's Avatar
Loony2N
That kind of rattle was addressed in another post this morning and may be coming from the plastic surround of the sunroof, not the sunroof itself. Does the rattle stop if you "vent" or partially open the roof?
Old Aug 23, 2007 | 09:21 AM
Tharkun's Avatar
Tharkun
Also check the sun screen that has been the solution for some.
Old Aug 23, 2007 | 09:30 AM
medilloni's Avatar
medilloni
My last R56 'S' had this problem too, but only in the closed position - yours too?
Dealer had 3 attempts to fix it, the third attempt - the good guys at the garage ignored MINI (who said adjust it again) found two locating pegs that the roof 'slots' into/onto as it hits the closed position. They made a plastic sleeve to fit over each peg/post - problem solved.
Explained this to someone here in the UK with the same problem, they told their dealer and they knew where the locating posts were and fixed that too.
Also. No wind noise whatsoever. (I mean the roof ).
Hope this helps.
Old Aug 23, 2007 | 09:35 AM
SandiePepper's Avatar
SandiePepper
yep my 03 had the rattle when open, it's one reason I didn't get it on the 06
Old Aug 24, 2007 | 05:00 AM
acebutt's Avatar
acebutt
No rattles , no noise . Only 1600 mi. on the mini and no bone jarring roads.
The sunscreen does like to creep open though.
Old Aug 24, 2007 | 05:58 PM
Coopaw's Avatar
Coopaw
Had mine for 1.5 months 4500miles and no problem so far.
Old Aug 24, 2007 | 06:33 PM
r56mini's Avatar
r56mini
I hope you get it sorted out.
A rattle free car is like a PC that never crashes. -r56mini
Old Aug 24, 2007 | 06:38 PM
Hogtied's Avatar
Hogtied
Originally Posted by mufflethis
Does your sunroof rattle?
For what I paid for this car, the sunroof damned well better not rattle... and neither should yours.
My advice is to take it back - pronto.
Old Aug 24, 2007 | 07:50 PM
artsmini's Avatar
artsmini
Had my MCS since May and have over 7000 miles.In the last few weeks my sunroof has started to rattle on rough bumps in the road. Just the rear sunroof. If I open it just a little it stops, and it also doesn't rattle in the full open position either. Gonna plan a trip to the dealer sometime . . .
Old Aug 24, 2007 | 07:56 PM
mufflethis's Avatar
mufflethis
So it runs Linux?
Edit: nevermind geek humor :P
Old Aug 24, 2007 | 07:59 PM
lhoboy's Avatar
lhoboy
My R53 rattled with the roof open. They replaced the whole roof cartridge. No problems since. Get it fixed before you go out of warranty.
Old Aug 24, 2007 | 08:26 PM
lucyl's Avatar
lucyl
My sunroof used to rattled very loud when its fully closed and only at 95 plus mph. I don't think it closed correctly. Doesn't do it anymore.
Old Aug 24, 2007 | 10:50 PM
billie_morini's Avatar
billie_morini
my auto is 28 months old. the sun roof does not rattle when closed. there is a little rattle when it is cracked open so that the back is up about 2 inches and the front has not moved backward much. when full open there is no rattle
Old Aug 26, 2007 | 06:07 AM
kimmc's Avatar
kimmc
I've had mine since may, with 3400 miles and some rough nyc roads, and I have NO sun roof rattle at all. Quite as a mouse. I have a little buzzing noise in my dash somewhere, but no sunroof noise.
Old Sep 10, 2007 | 04:31 PM
Montgomery's Avatar
Montgomery
You bet
RAttle? My '03 is driving me nutz! I think it is the fold down wind deflector. When the roof is closed I can fold up a sheet of paper and slip it under the right edge to stop the noise. I am going to try putting some tape on the edge of the deflector to see if that helps.
Old Sep 10, 2007 | 09:49 PM
daffodildeb's Avatar
daffodildeb
No rattles in mine!
Old Sep 11, 2007 | 05:36 AM
Trinity07's Avatar
Trinity07
Ive had my '07 since February and so far no rattles. Just some occasional groaning when I open it.
Old Sep 11, 2007 | 05:41 AM
pennyw's Avatar
pennyw
Thankfully, no sunroof rattle. But I do have a strange "squeak" coming from under the steering wheel.
Old Sep 11, 2007 | 11:38 AM
mystfynyou's Avatar
mystfynyou
No rattle for me, but i'm only 3 days in
Old Sep 11, 2007 | 03:22 PM
CUTiger3's Avatar
CUTiger3
No rattle with mine. Of course, it is rarely closed so...
Old Oct 15, 2007 | 10:45 AM
MiniWolf's Avatar
MiniWolf
Easy fix
4 strategicly place felt circles (like the ones that go on the bottom of a chair.) about .75 inch in diameter. Look for the little mark on the plastic wind deflector and place the small felt circles there. My rattle is gone.
Old Oct 15, 2007 | 01:03 PM
mufflethis's Avatar
mufflethis
Unfortunately my fix was more complicated than that. I took it in for service again 4th time to get the roof fixed had to have a technician go for a ride with me he found 2 spots that rattled, the plastic frame around the front panel of the sun roof and the shade. So they put padding around it. Now the rattling is almost gone except for when I hit a bigger bump on the road. I think it's the back frame and another noise that I can't identify.
Old Nov 27, 2007 | 09:26 PM
minimic's Avatar
minimic
i have an 06 MCSa and my sunroof rattles only in the vented position when going over bumps, but then stops after the first few bumps. i have taken it to the dealer several times and they could not find the problem.
stange,
