R56 Weird leaky windshield wiper jet
Old Jul 20, 2007 | 01:15 PM
Kasey's Avatar
Kasey
On my '07 MC one of the windshield washer jets has started leaking, but only while the car is turned off.
I can wash and dry/polish and everything is fine. I drive to my destination and everything is still fine. I can run my finger over the nozzle and it is absolutely dry.
I come back a couple of hours later and there is a line where a little dribble of fluid has come out of the nozzle and down the hood and then dried.
Last night I caught it in the act, sort of. I came back out after 20 minutes of the car sitting and the nozzle had a very small amount of liquid on it. It hadn't actually started to drip yet.
I keep cleaning it off and it is back every time the car sits. It doesn't matter if I used the washer jets or not, or if the car was washed in the last couple of days or not.
I hate to take it back to the dealer for only this and no maintenance is needed for 13k miles yet. It's making me pretty nuts.
Any suggestions? Any one else see this? Is the nozzle something I can just replace myself?
TIA!
Old Jul 20, 2007 | 01:16 PM
MrVvrroomm's Avatar
MrVvrroomm
My wife's '07 MCS was doing the same thing. She just had it worked on. I'm not sure what they did or if it worked. I'll have to go check it out when she gets home.
Old Jul 20, 2007 | 02:24 PM
Blue Skies 05's Avatar
Blue Skies 05
Mine is doing the same thing. Our cars are magical
Old Jul 20, 2007 | 03:45 PM
chili_red07's Avatar
chili_red07
mine did that too, but it stopped. maybe yours will too?
Old Jul 20, 2007 | 04:15 PM
manifest's Avatar
manifest
Both of my jets are leaking. They leak so bad they have left a stain on my bonnet stripes. A call to the dealership is in order.
Old Jul 21, 2007 | 06:52 AM
MINI Jackpot's Avatar
MINI Jackpot
Weird! I just noticed this about 3 days ago myself. Driver's side nozzle leaky! Undocumented 'feature'?
Old Jul 21, 2007 | 06:58 AM
korby's Avatar
korby
They stop after a few months.
Old Jul 21, 2007 | 09:14 AM
Hic's Avatar
Hic
My did the same exact thing, it did stop after a month or so. Unfortunately because the bonnet gets so hot, some fluid actually dried and left a small stain near the jets. Take it to the dealer before that happens to you...kinda sad this kinda of thing happens on a 30K car though , anyway Good luck !
Old Jul 21, 2007 | 10:23 AM
dwdyer's Avatar
dwdyer
Mine does this every now and then.
Old Jul 21, 2007 | 01:26 PM
JohnnyF's Avatar
JohnnyF
Did you get yours fixed up at the dealer? I've got stains on one bonnet stripe now and haven't yet been able to get it cleared off myself.
Old Jul 21, 2007 | 01:44 PM
CAP'N CRUNCH's Avatar
CAP'N CRUNCH
Mine leaks too.
Old Jul 21, 2007 | 10:47 PM
Hic's Avatar
Hic
No not yet , the dealer is about 190 miles from where I live; When I get the 10K service I will bring it to their attention. I don't think changing a bonnet stripe out is a big deal, hopefully your dealer will take care of it for you...
Old Jul 21, 2007 | 11:11 PM
Crusoe's Avatar
Crusoe
It's crying because you parked it or maybe it's just young and needs to mature and control it's emotions a little better.
Old Jul 22, 2007 | 09:41 AM
MINI Jackpot
...then, you refill the reservoir
Old Jul 22, 2007 | 10:19 AM
Coffeeman's Avatar
Coffeeman
Same problem here. I assume that its because the bonnet gets hot enough to fry bacon on...Probably boiling the fluid, which makes it expand.
Old May 15, 2013 | 11:41 AM
The M People's Avatar
The M People
I know it's an old thread, but the same thing happen to my 2012 MCS. It happened to me last year a couple of times and it's happening again. I check the washer reservoir is NOT full.
And I just spend 3 hours waxing it.
Any thought on the fix ?
Thanks.
Old May 15, 2013 | 04:58 PM
ocluck's Avatar
ocluck
several people have complained about this. check out link below.
https://www.northamericanmotoring.co...weeping-3.html
the consensus are that it leaks water due to dealer's fluids and lack of control valves that can be installed under warranty.
Old May 17, 2013 | 02:06 PM
bhegg's Avatar
bhegg
TSB info from the thread mentioned above:
This in the information regarding the leaking washers:
Mini washer nozzle leak:
TSB: Sim610106 general elec system
Fluid leaks from washer jets
Rear and now front as of 2007
Non return valve part no.
61688229249
Old May 17, 2013 | 06:57 PM
The M People
Thanks ocluck and bhegg for your reply and information.
Those are really helpful information when I bring my Mini in for the repair.
Old Jun 25, 2013 | 02:19 PM
06mcsworks's Avatar
06mcsworks
Windshield Washer System
My 06 MCS has suddenly developed washer problems. The rear stopped working altogether and the front pulses a dual squirt or two then just drools. The reservoirs are filled, the holes have been cleared and I can here the pump running when the switches are engaged. Can someone please tell me: #1 Where are the washer pumps (are there two or do the front and rear nozzles share the same pump)? #2 What is the easiest way to access the reservoir bottles so that I can check for a clog(s)? #3 Is there another useful Utube video available to assist me? They have been very helpful in the past.
Old Jun 25, 2013 | 05:23 PM
mattkosem's Avatar
mattkosem
61688229249
I had the fix installed on my 2013 a few weeks ago and it still leaks just as much as id did beforehand. I guess I'll have to try running it out of fluid and filling with something different next,
--Matt
Old Jun 25, 2013 | 09:07 PM
ammodave's Avatar
ammodave
This https://www.northamericanmotoring.co...357-post5.html worked for me.
Old Jun 26, 2013 | 12:06 AM
nrfitchett4's Avatar
nrfitchett4
haven't noticed that on mine, but think I might switch to vinegar/distilled water next time I need washer fluid.
bahman
Feb 14, 2016 10:29 AM
Scm68
Jan 27, 2016 12:33 PM
vulkandino
Oct 31, 2015 08:29 PM
WhinyR53
Sep 30, 2015 07:36 AM
Samhillrocks
Sep 29, 2015 12:55 PM
