R56 Running gas tank near empty
Old May 30, 2007 | 05:34 PM
jrebel's Avatar
jrebel
All,
Picked up my 2007 Mini in March. Named him Jagr. Pure fun to drive.
I know it's not wise running near empty. In a situation the other day I ran it down until the OBC said I could go 20 miles more before I found a place to fill up. It was scary but answered my question of how low can I go on gas. Mind you , I did not do it on purpose.
I just thought I'd let you know that in an emergency it can go that low.
Finally took a few pics.
Attached Thumbnails Running gas tank near empty-jagr-2.jpg   Running gas tank near empty-jagr-1.jpg
Old May 30, 2007 | 06:04 PM
4xAAA's Avatar
4xAAA
That is a really nice interior.
But somebody stole your clutch pedal!
Old May 30, 2007 | 06:12 PM
jrebel's Avatar
jrebel
That's funny. I wanted stick .... wife wanted auto so we settled on the auto cause I have the paddle shift. I had problem posting 2nd pic .... got it now.
Old May 30, 2007 | 06:14 PM
911Fan's Avatar
911Fan
I don't think it really matters other than the inconvenience of running out of fuel.
There's a fuel filter, after all. And the inlet to the fuel pump is at the bottom of the tank where all the sediment supposedly resides!
Old May 30, 2007 | 07:47 PM
dwjj's Avatar
dwjj
Once or twice is probably no big deal. I sure wouldn't do it regularly. The pump is immersed in the fuel, and the fuel cools the pump when it's running. If you start running too low, the pump will get warm then hot. That's bad for longevity. Do it often enough and the pump will fail early. That's an expensive repair.
Old May 30, 2007 | 08:35 PM
at7815's Avatar
at7815
Thanks for letting us know!!! The lowest I've gone is 36 miles left b/c of being too scared of the possibility of running out of gas
BTW - that is a great looking car!
Old May 30, 2007 | 08:45 PM
daffodildeb's Avatar
daffodildeb
Either of you two remember how many gallons it took to fill it?
Old May 30, 2007 | 08:47 PM
at7815's Avatar
at7815
About 13.2 here.
Old May 30, 2007 | 09:32 PM
911Fan's Avatar
911Fan
True, but once the pump is no longer pumping, the car is no longer running! So it's a bit of a moot point.
Old May 30, 2007 | 09:46 PM
ScottRiqui's Avatar
ScottRiqui
It would depend on whether the pump is cooled by the fuel being pumped through it, or by the fuel in the tank surrounding it.
If it's the fuel passing through the pump that cools it, then there's no need for concern - as 911Fan pointed out, as soon as the cooling flow of fuel stops, so does the pump.
Old May 31, 2007 | 12:42 AM
msh441's Avatar
msh441
13 miles left!?! That's nothing!
I had mine down to 3 miles... and it was reading --- miles as I pulled into the gas station (with no hint of sputtering or stalling).
I seem to remember it took somthing like 14.6 gallons to fill back up!
Old May 31, 2007 | 12:44 AM
msh441's Avatar
msh441
Though I obviously wouldn't recommend anyone else push it like that...
Old May 31, 2007 | 03:19 AM
dwjj's Avatar
dwjj
I don't agree.
The "fuel pump" is an assembly-motor and pump. The actual liquid pump part of the assembly may have fuel going through it, but the electrical motor wouldn't. The motor would have to be cooled externally. I've had several go bad and had them apart on different vehicles (I fix them myself so see them firsthand). The motor is lightweight, and there's no where else for the heat to go. It's not designed to get enough cooling dumping to ambient atmosphere if it's not in liquid. No cooling fins or anything, lightweight metal motor body, won't transfer heat across to the actual pump part. Looks a lot like a motor in a toy.
(a few quick google results)
http://www.carx.com/AutoRepairandSer...1/Default.aspx
http://www.athomemechanic.com/archiv...your_fuel.html
http://www.popularmechanics.com/how_...36.html?page=2
http://www.donsautomotive.com/urbanlegends.html
If you continually run low tanks, you'll also have more condensation inside the tank. More water in the fuel isn't good either.
Old May 31, 2007 | 03:43 AM
jrebel's Avatar
jrebel
Down to 3 miles .... wow. Talk about being nervous? Good to know in an emergency.
Old May 31, 2007 | 03:55 AM
Skuzzy's Avatar
Skuzzy
The first time I filled Romi, I was not sure when would be a good time to fill her, so when she complained at 2 candy corns, I immedaitely pulled into a station and refuled. She took 12.1 gallons U.S. I recall the compture saying she had 80 miles left to go before being empty.
Assuming this was based on the AVG CON, which was 26.2, she had about 3 gallons left. So she carries just over 15 gallons of fuel, if the computer is correct.
I will let this second tank run down to the same point and refill at the same pump to see if it is consistent.
Old May 31, 2007 | 04:45 AM
daffodildeb
Please report the gallons, would you, Skuzzy?
Old May 31, 2007 | 04:46 AM
msh441's Avatar
msh441
No, no! The reading dropped BELOW 3 miles!
It flashed 2 for about 10-seconds, then actually displayed "--- miles" for the last 1/2 mile or so rolling into the station.
Old May 31, 2007 | 04:56 AM
dreman's Avatar
dreman
So when should we fill up regularly? Mine is down to the two red bars, and says I have 60 some miles left. This would be my second fill up, my last I did with about 25 miles left in the tank. This normal?
Old May 31, 2007 | 04:59 AM
Yucca Patrol's Avatar
Yucca Patrol
Heck, that is nothing. . . I've had it display the --- and then start counting back up for a few miles. . .
Old May 31, 2007 | 05:03 AM
JAB 67's Avatar
JAB 67
On several occasions I have driven several miles with the 'range' (i.e., miles to empty) reading "---". Never took more than 13.2 to fill, as I recall.
Old May 31, 2007 | 08:22 AM
Need's Avatar
Need
When I test drove the MCS, the OBC shows 3 miles left, but the salesman wasn't worry. I think it was still 3 miles after we drove for least 1.5 to 2 miles.
Old May 31, 2007 | 09:14 AM
Birdman's Avatar
Birdman
jrebel,
What interior fabric is that? Looks like the Leatherette, but what colors? Standard black or something else....?
Old May 31, 2007 | 10:34 AM
daffodildeb
Need--one of the MA's test drives ended in embarrassment around the time we were shopping...
Old May 31, 2007 | 10:39 AM
minimaximini's Avatar
minimaximini
Don't do like me
I drove (a 06 MINI ... loaner) with ZERO Miles range for... 4 miles until I found a gas station.
But frequently dipped in the single digits. The fun part starts when teh car sputters a bit at less than 5 miles range.
Just have your roadside assistance number handy.
MMM
Old May 31, 2007 | 06:03 PM
jrebel's Avatar
jrebel
Quite a risktaker huh? I could not do that. Chickened out.
