R55 N14 oil ring issue
Old Nov 3, 2023 | 11:41 AM
Zaffer's Avatar
Zaffer
N14 oil ring issue
I am in the process of rebuilding my engine and I have run into a problem. I ordered Mahle piston rings, P/N 11 25 7 566 479 , and I am running into an issue with the oil ring not fitting. It is the 5-ring set (I believe that is all you can get now) and the piston rings are 1.20mm (top), 1.50mm (middle), and 2.00 (bottom). When I put in the two scraper rings, the separator(?) ring will not fit between them. I have checked for other ring sizes and I cannot find them at the moment. I checked RealOEM and the part number is correct and there is no other P/N or ring size listed for my engine. Build date is 01/2009. Am I missing something or doing something wrong? I didn't have this issue with my M54 rebuild in my e46, but that's a different car/engine. Has anyone else run into this issue?
Thanks!
Old Nov 3, 2023 | 12:04 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I could be wrong, as I haven't installed Mahle rings before, but I believe the center ring goes on first, then the two top and bottom scraper rings.
So they get stacked up like this:
Old Nov 3, 2023 | 02:14 PM
Zaffer's Avatar
Zaffer
That’s exactly how they install. I went back out to the garage after posting, inspected the rings, and noticed the raised portion on the inside of the middle piece. I then deduced that it needed to go on first so that the scraper rings hold it in place.
I like the diagrams and thanks for the excellent reply!
Now that that’s out of the way, I have another question: what’s the best way to install all of said rings? I saw a thread on this but the explanations were a little muddy. I believe they were trying to explain it like this:
1st/Top ring is oriented at 10:30 with the split facing 45 degrees off of the front of the engine/direction of the arrow on the piston.
2nd/Middle ring is oriented at 1:30 with the split facing 45 degrees off of the front of the engine, or 90 degrees from the 1st ring.
3rd/Top Scraper ring is oriented at 7:30, with the split 45 degrees off of the back of the engine.
4th/Spacer ring is oriented at 6:00, with the split facing the rear of the engine.
5th/Bottom ring is oriented at 4:30, with the split facing 45 degrees of of the back of the engine, or degrees from the top scraper ring.
Is this correct?
Old Nov 4, 2023 | 04:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I’ve always heard that you want rings gaps to be 180° out of alignment. Not sure if overall orientation to the connecting rod or engine matter as much…
Old Nov 4, 2023 | 10:16 AM
Zaffer's Avatar
Zaffer
I had heard that as well. I did that on my e46 engine without issue, but that only had 3 rings. The info I have above I got from Summit Racing and it mostly matches what I found on the Mini2 forum (where the info was a little muddy).
Just wanted to see what other people’s experiences were, especially those who are more experience in rebuilding these engines.
Old Nov 6, 2023 | 09:48 AM
Zaffer's Avatar
Zaffer
Okay, now the fun of getting the pistons in is taking place! What ring compression tool is a good one to use? I have a band-clamp style from when I did my e46 engine rebuild and had no issues, but am having issues with the Mini piston rings. The following occurs:
The tool isn’t able to evenly compress the rings, so it’s not able to compress the rings enough to get into the bore. The other issue I see is that the scraper rings are thin and “pop” out in the transition from the tool to the bore, preventing any further insertion.
I was looking at the conical style, which seem to have good ratings, but unsure as to exactly which one I need. Some places I see bore size at 77.0mm, others say 77.5mm. Should I just go with the 77.0mm? What do others use?
Michael2007Mini
Dec 18, 2018 12:20 PM
Mininewb101
Nov 6, 2018 08:52 AM
Bcoday
How to
Jun 23, 2018 08:19 AM
Bcoday
May 19, 2018 08:07 AM
genik
Aug 29, 2013 12:41 AM
