R55 How to install 3rd brake light on 2010 Mini Clubman??
Old Aug 8, 2019 | 01:24 PM
CooperClubman's Avatar
CooperClubman
I need to install a new 3rd brake light on a 2010 Mini Clubman (R55). Any helpful hints. I see four torx bolts holding the housing on?? After I remove those, what do I need to do?
Old Aug 17, 2019 | 07:04 AM
bugeye1031's Avatar
bugeye1031
Moderator
It's been a long time since I removed mine, but if I remember correctly, after you remove the torx screws the trim assembly with the third brake light slides backwards toward you. The wire for the light has to be disconnected before you pull the assembly very far, but there isn't a trick to it. Best of luck.
Old Aug 20, 2019 | 07:24 AM
More info here: https://www.northamericanmotoring.co...n-clubman.html
bilk
R55 :: Clubman Talk (2008+)
Jan 11, 2019 11:01 AM
njaremka
Apr 30, 2018 04:56 PM
03mini-S
F54 :: Clubman Talk (2015+)
28
Feb 19, 2017 03:05 PM
MothAudio
Mar 4, 2016 01:08 PM
MiniKar
Feb 2, 2010 10:02 AM
