R55 Rough start
Old Jul 6, 2019 | 06:50 PM
soulala0593's Avatar
soulala0593
Rough start
So I’m having a 4th cylinder misfire code pop up but the problem is at start up. It’s like it doesn’t hit 1rpm when it starts so it turns off, bounces around 500 rpm and then turns off, or just stays at 500 but won’t register the gas pedal. Is having some other minor stuff like slow to shift gears.
Checked the spark plugs and the coils. Replaced the VANOS, wasn’t it. Fuel injectors recently cleaned but before this started happening. HPFP replaced last November but the signs for that were very different than this.
Here’s a link to the videos.
https://drive.google.com/drive/folde...2PJdmTyOnytd0s
Old Jul 8, 2019 | 11:33 AM
MiniToBe's Avatar
MiniToBe
my bad HPFP is making that car act the same as what you have...after at least 5 or 6 cycles of shutting down, it catches up and becomes normal.
I also had another mini doing the same because the gas tank purge valve was disconnected.
even though the car just developed this issue, I would remove the valve cover and inspect the timing chain and the timing.
ericmakkar
May 20, 2011 05:16 PM
ronmichael
Jun 6, 2007 09:05 AM
topgearnut
Jul 26, 2006 03:23 PM
sright
22
Sep 2, 2005 07:03 PM
MINItura1
Jun 16, 2005 05:34 AM
