R55 Check Engine Light
Old Nov 16, 2015 | 12:18 PM
fozcycle's Avatar
fozcycle
Check Engine Light
I have a 2011 Clubman with 60k miles.....The Check Engine Light came on yesterday.....not flasing, just solid amber color.
Any ideas?
Old Nov 16, 2015 | 12:26 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You'd have to plug into the OBDII and pull the code that is causing the CEL to trigger. Start there and post what the code is. Any symptoms with the light?
888.280.7799 | 6am - 5pm PST
Old Nov 17, 2015 | 07:28 AM
fozcycle's Avatar
fozcycle
What is an OBDII?
Old Nov 17, 2015 | 07:35 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
It is a diagnostic port usually on or near the wall at the drivers side footwell. Been in cars since the 90's as I recall. You can buy a cheap reader or adapter for your phone. Several auto parts stores will read the codes for you for free.
Old Nov 17, 2015 | 07:41 AM
fozcycle's Avatar
fozcycle
Thanks, my brother works for NAPA.......will get one through him.
Old Nov 17, 2015 | 08:18 AM
PelicanParts.com
Vendor
Yes, and do note that some generic code readers cannot read all codes being thrown. If you plan to work on your MINI in the future as well, it may be a good idea to invest in a good diagnostic scanner for your tool kit. Let us know what you find and if there are any other symptoms that you're noticing.
Old Nov 17, 2015 | 09:03 AM
Any ideas?
Get a code reader and see what code comes up.
Old Dec 2, 2015 | 08:09 AM
fozcycle's Avatar
fozcycle
Borrowed a reader from Advance Auto....code is P300.
I tried to erese the code but their readers are not equipped to erase codes.....
Any ideas?
Old Dec 2, 2015 | 08:22 AM
PelicanParts.com
Vendor
You sure it wasn't P0300? That code means Random/Multiple Cylinder Misfire Detected.
Old Dec 2, 2015 | 08:25 AM
Minnie.the.Moocher
http://www.obd-codes.com/p0300
Invest in a wifi dongle, less than $20 and with free apps on your phone you can erase codes. Some of the better pay for apps will likely give you better info.
Old Dec 2, 2015 | 08:55 AM
fozcycle's Avatar
fozcycle
That is correct.....P0300
Old Dec 2, 2015 | 11:44 AM
Check the coils and the plugs, sounds like bad coils.
polibureau
Sep 9, 2016 08:44 AM
luisfv56
Dec 9, 2015 09:25 AM
IDoSeaDoo
Nov 6, 2015 08:41 AM
IDoSeaDoo
Oct 26, 2015 06:20 AM
Sumeet_r56
Oct 21, 2015 10:16 AM
