R55 Hot Hood ( ok Bonnet )
Old Oct 11, 2013 | 06:13 PM
  #26
rckrzy1's Avatar
rckrzy1
Ok they only installed metal shield, guess the
Padded one would have blocked vent in scoop
Either way it measured 150F now , so it has
Helped.
Old Oct 11, 2013 | 09:40 PM
  #27
kacken's Avatar
kacken
I have the stock metal heat shield on mine but plan to add the nm titanium one as well. They also make heat shields for the hood to help keep some of the heat from doing any damage. I know nm and way motor works has them which I plan to get as well. I used to have an eclipse that gave off crazy amounts of heat and I did the same thing to the hood and it seemed to help
Old Oct 12, 2013 | 07:48 AM
  #28
rckrzy1's Avatar
rckrzy1
I prefer to block the heat from getting to the bonnet, not so keen on the idea of trapping heat in the engine.
Old Oct 12, 2013 | 09:46 AM
  #29
kacken's Avatar
kacken
It sits just above the turbo. I added a link. Check it out if you're interested as it is made to save the scoop from warping
http://www.nm-eng.com/nm688855-nm-eng-scoop-saver.html
Old Oct 12, 2013 | 09:57 AM
  #30
rckrzy1's Avatar
rckrzy1
Yes I have seen that. Right now I just added some self adhesive heat shield just in front of the scoop to cover the area not covered by factory shield and it's now 138F max and avg is about 120F , much better as I was reading 165F to 185F before, now you can actually feel the heat escaping out the scoop, it measures about 210F but the heat is leaving and I like that. Not worried much about melting as with 200 miles on my car got alot of warranty left
Old Oct 12, 2013 | 10:17 AM
  #31
kacken's Avatar
kacken
Good to hear it's doing better high heats like that are never fun
Old Oct 12, 2013 | 11:02 AM
  #32
6thGear's Avatar
6thGear
Nice! What self adhesive heat shield are you using?
Old Oct 12, 2013 | 12:08 PM
  #33
rckrzy1's Avatar
rckrzy1
Thermo Tec 13500 Adhesive Backed Heat Barrier
Got it on ebay for like $13 shipped for a 12x12 piece, cuts easy and is flexible.
Boverphoto
Jul 3, 2017 10:56 AM
YO MUDA
Oct 5, 2015 04:14 PM
Jolio
Factory JCW Talk (2009+)
Sep 17, 2015 09:23 PM
MiniChick82
Sep 16, 2015 02:56 PM
Sep 3, 2015 01:45 PM
