R55 Questions about 1st Mini Purchase. 09 Clubman JCW. Questions?
I am super close to buying an 09 clubman JCW. It has 91k and is a 6spd. Here is what I know:
Pretty regular maintenance completed by a BMW/Mini but the oil changes were done at about 15k
Water pump done about 20k ago
Turbo replaced about 10k ago
The car is immaculate I'm just nervous about the higher miles and I've never had a Mini before. (I've had a couple VW's and an Audi)
Also this mini is over 8 hours away. (I did drive a clubman S here locally and really liked it but I want the JCW)
What should I look for when I test drive it etc.
Should I schedule an apt at mini so they can look it over?
Anything else I should know or look for?
Appreciate the help and info!
The mileage would be a concern of mine too.
By all means have a MINI dealer look it over.
Unless you are getting this at a super fantastic price - I'd look for one with less miles.
Good Luck!
Good Luck!
Unless you are getting this at a super fantastic price - I'd look for one with less mini with less miles
Good Luck![/QUOTE]
I'm getting it about 5k below KBB retail. Think that's worth it?
Good Luck![/QUOTE]
Out of curiosity, is it reasonable to expect a turbo to need replacing at 80k? And what generally causes one to go out? Regular wear and tear or driving like a madman at every opportunity? And what's the cost to replace one? Thanks,
Mike
Mike
The only thing I would really be worried about would be timing chain stretch and carbon buildup. Other than that any mechanic should be able to look it over and give it a thumbs up/down.
Just bought one with 93K miles on it.
I bought it from an independent BMW shop that does a lot of work on M cars and BMW/Mini race cars as well . Also serviced my (Former)Z4m .
Im not afraid of miles on cars. Its all on service history. Ours had , timing chain & tensioners done, HPFP, all new brakes rotors etc, tires And they serviced it since new. So I was lucky to get the full service history since new.
Have the car checked out, thats the big thing. If you can find an independent shp that specializes in BMW/Mini Ive always found them to be more reliable .
15K is a long stretch between oil changes. If your gut has you second guessing , maybe getting a second opinion would be wise.
Listen for any rattling noise at start-up from the passenger foot well. Turn the A/C off, as the compressor makes a noise at start-up that can be mistaken for a slack timing chain.
Check the brakes, check the clutch, check that it does all the electro-wizardy stuff it's supposed to.
Make sure it has both keys. The little buggers are VERY expensive!
As Jean Calvin said, "Good luck!"
This sounds like one I was considering. I only looked at it online and ended up buying a 2010 S with 7K on it. I tend to hold onto cars for a long time (14 yrs on the last) and decided to go the low mileage route.
Was this a Sparkling Silver JCW? Did you end up buying this one?
SosoMINI
Nov 22, 2015 03:17 PM
marendt428
Nov 14, 2015 10:03 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
