R55 Justa catalytic converters
My local mechanic thinks my catalytic converter honeycomb is breaking up internally. My Justa has 90 K on it. In addition, my heat shield is broken and the rattling is very annoying. Two questions:
1. Has any Justa owner used a Magnaflow exhaust header/catalytic converter and your opinion of it?
2. Is there a need or requirement to using the heat shield?
Any comments/recommendations would be greatly appreciated.
J. Shook
J. Shook
08 Justa catalytic converter
My Justa is an 08. Warranty expired at 80 k or so the dealer told me. That was one of the first things I checked. Mini dealer wants $2k, $1200 for the catalyst and the remainder for labor. The Magnaflow is $600-700. Thanks.
Check the laws in your state, i know in CA they are crazy strict about what converters you can use. If the converters have the same cells per inch or whatever the measurement is then flow should be equal. No experience with that cat, but it should be fine. And I would keep the heat shield in
elverado
Jan 18, 2022 02:51 AM
F55/F56 JCW Pro Coilovers... on a Justa
MidnightF56
Sep 10, 2015 01:04 PM
