R55 How to disable passenger seatbelt chime?
Is there a way to disable the passenger side seat-belt chime without doing any heavy modifications?
Now, before people go on and on about telling me about how dangerous no seat-belt is and I'm next in line for the Darwin Award, I completely agree that not wearing your seat-belt is absolutely stupid and everyone absolutely should wear it whether they're going 10 feet or 10 miles. I won't start my car unless everyone is wearing their seat-belt.
So why do I want to disable it? Because every now and then I place something in my front seat and even things that weigh less than five pounds set off the sensor. This morning I had a small box with several bags of tea in it that couldn't have weighed more than two pounds and the sensor went off. It's simply a massive pain.
If there isn't a way to turn off the sensor, can I just adjust the sensitivity so that it goes off at even something still small like 10 pounds?
Unfortunately, the lawyers at BMW/MINI have artfully seen to it that the answer to all of your questions is "No, that's not possible."
You'll need to seek out a more direct, after-market solution like this little gizmo.
I set my gym bag and other random things on the passenger seat and have never had the seatbelt chime go off. The only thing that happens is the passenger air bag off light illuminates. Maybe the sensor in your passenger seat is defective (or maybe mine is!)
If you have relatively lightweight objects setting off the warnings, try placing a folded towel on the seat under the object in order to spread the weight around a little more evenly.
That would be too easy! Haha. You could always order one of these: http://www.outmotoring.com/mini-coop...top_chime.html
Having the sunroof/windows open using the keyfob is a *standard* feature. *Closing* them is not a standard feature, but it can be activated using the NCS Expert software. I really like this capability, it comes in handy when it's pouring outside and you forgot to close your windows and/or sunroof - doh!
You can also enable 1 touch sunroof open/close using NCS Expert...You can also disable the seatbelt chime using NCS Expert. The chime *does* sound (4 times) at startup, but after that the chime will no longer, uhhhh, chime regardless of the status of the seatbelt buckle. It also does not chime if the door is open with the key in the ignition with accessories pwoered-up. I really like this because it allows me to work on the car with the door(s) open without having to listen to that annoying chiming...
The cheapest solution. My passenger side seat belt is always buckled. I originally started doing this because the buckle would rattle against the side pillar and annoy the %$#& out of me.
Annette
I tend to agree. Personally, I'd try the approach of using the seatbelt buckle out of a MINI in one of those "U-Wrench-It" places...
I would imagine that there's some way to disable the chime through NCS Expert programming.
But yes the seat has more than just a single pressure sensor in it. It is actually a set of 5 sensors that also monitor where the pressure is to tell what size the object is that is sitting in the seat.
It's not an isolated incident, either, so I'm suspecting the antenna or some part of the phone is messing with the system. Kind of like how my old Nextel phone used to trip the GFCI in the kitchen when I left it too close.
For me, it's my old 20 lb dog that sets it off. My other dogs aren't allowed up front, but it's where he's entitled to be.
i have my phone on my passenger seat on an almost daily basis, never had the chime go off. also i put my work bags on that seat daily as well, and it never goes off. i mean yesterday i had one text with me that weighed probably 4-5lbs on its own, and all i got was the airbag off light going on and off the whole trip.
Funny enough that this thread got res'ed, I just got a new Countryman and my phone with my GPS app was setting it off last night.
When I use Waze (GPS) my iPhone gets incredibly hot so no idea if it was the heat or electric current from the phone but either way it was annoying. Old Mini was a 2008 (I think) Clubman, this one is a 2013 Countryman.
Can't you just buckle the seat belt
