R55 Problem filling up at the gas station
Hi
I have a rather strange issue with my Clubbie. Every time I refuel I can't pull the gas pump handle all the way without it clicking and ceasing to pump fuel (the same sensation that happens when it thinks the fuel tank is full). In order to fill the car I have to hold and find the point just before the click/cease triggers. This often means the car fills really slowly.
Is this something other people have experienced? I'm going to call the dealership this week to see if they've heard of it before.
Cheers
Cheers
I have not notice that but I live in OR where we are not allowed to self serve fuel. Also the attendants are not allowed to 'top off' the tank after the pump stops. So I buy gas in 5 gal containers and top off at home when going on a long trip. I can get at least another gallon or 2 in after a 'fill'' up. However in order to fill from tanks I have to stick a screwdriver down the little trap door thing to hold it open else gas just dumps onto the ground. Kind of annoying.
Have you tried different station or brand?
Does your location require the fuel vapor capture type filler hoses like in CA?
Had that problem on one of the tanks on my old truck. I would have the hold back the vapor thing and pump most of the tank holding the nozzle with both hands. Turned out to be a problem with the air return tube inside the tank filler hose.
Rotate the hose attached to the nozzle toward the front of the car and you should find it much easier to get the tank to fill without premature shutoff.
cornfly888
Aug 24, 2015 09:57 AM
Steffen.Johnson
Aug 23, 2015 08:30 PM
dchang0
Aug 10, 2015 03:37 PM
