R55 Removal of chrome around headlight?
Old Apr 21, 2010 | 02:15 PM
mbu's Avatar
mbu
I have a '09 Clubman and I need to remove the chrome fixture on the hood that surrounds the headlight. The chrome is held on by a number of clips. How are these clips removed...is there a special tool?
Thanks...
Old Apr 21, 2010 | 08:21 PM
Vinyl Styles's Avatar
Vinyl Styles
Your thumb
Just push on the tabs towards the center of the ring.
Old Apr 22, 2010 | 09:34 AM
mbu's Avatar
mbu
Lagston@VinylStyles,
Thanks for the reply! I'll give that a try.
Old Jan 25, 2011 | 12:48 PM
Torri91's Avatar
Torri91
Good to know since I will be doing the same once I get my blackout parts from VinylStyles.com
Old Jan 25, 2011 | 01:38 PM
dannyhavok's Avatar
dannyhavok
Would this apply to the Xenons on my '06 R50 as well? I'd like to black them out.
Old Jan 31, 2011 | 01:04 PM
Vinyl Styles
I wish it did.
The 02-06 headlight rings are a bit tricky to get off.
The whole headlight assembly needs to be removed to gain access to the headlight ring tabs.
Old Jan 31, 2011 | 04:59 PM
Greg Davis's Avatar
Greg Davis
Slight Hi-Jack Alert!
Lyle, have you noticed a difference in the headlight rings between the new 2011's vs previous years? The dealership said earlier grills won't work on the 11's and that even the hood has a different P/N. I didn't realize thay had changes that much!
I have a spare set of rings off of my '08 and was going to have them painted, but wanted to make sure they will fit my '11.
OK - Hi-Jack is Off...............Sorry about that.
Old Jan 31, 2011 | 05:04 PM
dannyhavok's Avatar
dannyhavok
Originally Posted by Lagston@VinylStyles
I wish it did.
Good to know, thanks! Looks like I'll be leaving them alone or taping off and plasti-dipping.
Old Jan 31, 2011 | 05:07 PM
Vinyl Styles
The headlight rings from the 07-10s will work on the '11s. I've swapped some out already.
I can't confirm the front grille. The upper piece should be universal.
I wouldn't be surprised if the bottom piece is different.
MINI sometimes changes the smallest things, and they'll really throw me off.
Old Feb 1, 2011 | 08:46 AM
Greg Davis's Avatar
Greg Davis
[quote=Lagston@VinylStyles;3205220]The headlight rings from the 07-10s will work on the '11s. I've swapped some out already.
quote]
Thanks - That's exactly what I needed to know!
Alkaidovich
Jan 30, 2021 01:35 AM
Dec 23, 2015 10:36 AM
Powershift
Aug 16, 2015 05:14 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
