R55 Door Panel Removal
Old Feb 15, 2010 | 09:51 AM
Kewlbreeze's Avatar
Kewlbreeze
Door Panel Removal
I want to install new speakers in a MCC. I have a lot of threads about door panel removal, but they are not directed at a Clubman and in particular they do not address the clubman door or the drivers side rear speaker.
Does anyone have directions on door panel removal and dealing with the rear speakers in a Clubman? Somebody must have done this already...
Also, what is procedure for removing the sill plates so as to run wire underneath?
Dennis
Old Feb 15, 2010 | 10:24 AM
slimjimtell's Avatar
slimjimtell
Im not sure about the doors panels, but I can help you with the Sill Plates...
DO NOT REMOVE THE SILL PLATES!! you will break every clip removing them.
Remove the lower kick panel that is left of the pedals and is around the hood release.
  • Remove the "lower kick panel" that extends to the back of the door.
  • It is on the INSIDE of the car
  • Gently start at the kick panel by the pedals
  • Get your fingers behind the panel and pull. The plastic clips will release
  • Work your way towards the back of the door.
  • When you get to the seam in the plastic an all clips are released, slide the kick panel towards the front of the car and remove
Replacing
  • Make sure all white plastic clips are off of the car. replace them in the slots on the kick panel.
  • Start at back by sliding the kick panel in
  • snap each clip in
  • Pull rubber weather strip back over top of kick panel. I use a plastic screw driver and slide it back on.
I hope that is what you are looking for.
Old Feb 15, 2010 | 10:43 AM
ron-s mini's Avatar
ron-s mini
Here is link: to a "how to with pictures"
http://www.motoringalliance.com/libr...eplacement-60/
greekzilla
Aug 23, 2015 03:44 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
Getrieben
Aug 15, 2015 09:09 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
