R55 Do You Hear a Lot of Wind Noise From the Sunroof, When Closed?....
Old Jun 2, 2012 | 09:31 AM
  #51
houlster's Avatar
houlster
Originally Posted by pmsummer
Old thread, I know, but very helpful. My '09 R55 has what I consider excessive wind noise from either the top of the windshield or the front of the sunroof (closed). No water leaks into the interior, just lots of noise at any speed above 50 mph. I mentioned it to the SA when I had the car in for the recall, but he said the only problems he had seen came from replaced windshields not sealing well.
Based on what I've read here, it's an issue I'll pursue with the dealer before my warranty expires!
Pursue it. My '08 was very noisy as well from when I got it at 18k miles (2nd owner). Mini replaced the sunroof seal under warranty and it's quiet like a coffin inside now in comparison. The dealer said it was common for the seal to shrink and get noisy in the AZ heat.
--Dan
Old Jun 3, 2012 | 04:49 AM
  #52
pmsummer's Avatar
pmsummer
Originally Posted by houlster
Pursue it. My '08 was very noisy as well from when I got it at 18k miles (2nd owner). Mini replaced the sunroof seal under warranty and it's quite like a coffin inside now in comparison. The dealer said it was common for the seal to shrink and get noisy in the AZ heat.
--Dan
Thanks, I will... (as soon as the new hood scoop comes in)!
Old Jun 7, 2012 | 12:02 AM
  #53
FRANKr56's Avatar
FRANKr56
I get a slight wind noise from my driver side window. Unsure if it is the same on the passenger side... always a driver never a passenger. Can someone confirm if there should be zero wind noise?
Old Jul 13, 2012 | 03:07 PM
  #54
eppyphotog's Avatar
eppyphotog
Just had my sunroof seal replaced under warranty on my 09 Clubman S for the same wind noise. AZ heat just dries these out. Driver window was not going up the extra 1/2", upon trying to reprogram the dealer said my main communication computer would crash.They replaced the entire "CCC" computer under warranty. Next it goes in for the hood scoop replacement. Lots of rattles to sort out.
Old Jul 13, 2012 | 05:14 PM
  #55
pmsummer's Avatar
pmsummer
Got my '09 Clubman S back today with new seals as well. No side window problems.
I haven't had sunroof and window seal problems in a car for almost 40 years... since I last owned a BMW. ;-)
Old Jul 13, 2012 | 05:37 PM
  #56
eppyphotog's Avatar
eppyphotog
I never had a sunroof problem on my 2003 BMW 325iT or my 1975 BMW 2002.
rikaro
Aug 7, 2021 02:33 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Toolman
Jan 20, 2016 06:50 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
elightbo
Aug 17, 2015 01:50 PM
