R55 Mini Do More hitch install
Old Oct 8, 2009 | 08:58 AM
  #101
austex's Avatar
austex
Originally Posted by taysan
I ordered my hitch last night - big sale on - $50 off the now lowered price of $190, so you're paying $140 + shipping for the hitch. Too good a deal to pass up!
Don't I feel special for having paid $325....
Old Nov 2, 2009 | 06:45 AM
  #102
ediebucket's Avatar
ediebucket
Problems with brake lights on teardrop
We have a 2009 clubman S and a mini do more hitch to tow our tear drop trailer. We paid 500.00! to have the lights hooked up to the trailer. (7 pin hitch). All the lights work but the brake lights fail after a few minutes. The mini computer says bulb error. The people who installed the wiring want another 500.00 to fix it claiming it's very complicated. Are we getting hosed? or is there a simpler, cheaper solution? We can't enjoy our teardrop till the brake lights work...
Old Nov 2, 2009 | 06:50 AM
  #103
taysan's Avatar
taysan
Who's doing the work? $500 seems very very very high for what should be a simple job. Anyone who charges you $500 to do a job, and then wants another $500 to fix the job is hosing you. Whether $5 or $500, you paid to have a job done.
Run as fast as you can from whoever did the work and chalk the $500 up to a learning experience.
I'm sure there's a member on the board in your area that has had this done somewhere - take the car to a place that installs trailer hitches.
  #104
MyroMini's Avatar
MyroMini
I had the exact same problem with my trailer (only 4 wires though)
The problem was not the install on the Clubby, but the trailer itself. In one of the brake lights, 2 wires were not at the "right" place. Took the installers 10 minutes to fix.
Did you try your teardrop with another car, to make sure it works ok? Or have it tested?
Old Nov 2, 2009 | 07:03 AM
  #105
ediebucket's Avatar
ediebucket
We did take it to a big RV place here on Cape Cod. When they said how much more it would cost to make it work (500 at least in hours) I asked if I could have the first 500 back for the job that didn't work. They said Ok but that they would take out all the stuff they put in which DID make the turn lights and runner lights work, which was at least something!! WQe have hooked it up to my husbands truck (4point) and the brake lights work. We think if we adapt the 7 point to a 4 point it would be fine. The teardrop came with a 7 point. Thank you so much for the quick replies
Old Nov 2, 2009 | 07:11 AM
  #106
ediebucket's Avatar
ediebucket
Actually the husbands truck is also a 7 point. He says the difference is that his truck doesn't have a sophisticated complicated computer in it as the Mini cooper does.
Old Nov 2, 2009 | 07:25 AM
  #107
taysan's Avatar
taysan
I'd get the $500 back if it were me. You could probably get the folks at BMW to do it for less.
Old Nov 2, 2009 | 06:49 PM
  #108
SaltNPepa's Avatar
SaltNPepa
If the MINI computer is saying bulb error then I would guess they hooked the lights up by taping into the mini leads directly so your MINI is powering the lights of the trailer. From what I have heard this is not the way to go. I installed a powered adaptor based on the instructions you will find earler in this port.(cost about $35 and took less that an hour to hookup now my trailer is just 4 pin) and it works great. The powered adaptor takes power for the battery and used the MINI leads for signal only so your MINI does not know there are extra lights. If they hooked your lights directly to the MINI it now will sence a problem with the current going to its circuts and probbaly shut stuff down(which I guess it what you have happening.)
Old Nov 14, 2009 | 09:57 AM
  #109
zsqure's Avatar
zsqure
Yes the mini adaptor sold by brent at mini do more is easy to install, takes about 45 minutes (longer with a couple beers) and WORKS. I pull a little aluminum utility trailer.
Old Nov 16, 2009 | 07:02 AM
  #110
rexicon's Avatar
rexicon
What's the max # of bikes you guys feel comfortable hauling in one of these hitch racks. Would 4 road bikes @ 20lbs a piece be too much strain on the hitch?
I'm being a nervous nellie but I'd hate to see someone's $10k Colnago scraped all over the highway...
Old Nov 16, 2009 | 07:13 AM
  #111
JimRoberts12's Avatar
JimRoberts12
i've carried 2 lemonds several times and didn't notice it. i'd say if you're worried get a better rack. i just got a cheapy as i'm not going to far with it. but even at 100lbs i don't think there's anything to worry about. i'd be more nervous about making sure they don't swing into the bumper. make sure you put them on carefully to avoid that.
Old Nov 16, 2009 | 12:00 PM
  #112
rexicon's Avatar
rexicon
So the Thule/Yakima vs an Ebay $40 cheapie then...
Old Nov 17, 2009 | 06:32 AM
  #113
JimRoberts12
i think it just depends on your comfort. i got the cheapie. the thule or yakima are clearly better but there isn't a lot to the metal rack. the thing you have to be mindful of is how the bike attaches. i reinforce it each time i use it with tape and straps. i'm sure the expensive one are much better.
so in a nut shell you either spend the $ and have peace of mind or you get the cheapie and have to rig it up a bit. either way you'll be fine.
Old Nov 18, 2009 | 10:13 AM
  #114
TheMadDane's Avatar
TheMadDane
The Saris Thelma Racks Rock....
http://www.saris.com/p-298-thelma.aspx
They're very strong extremely compact and light weight, keep your bikes from rubbing and are the easiest loading/unloading rack I've ever come across.
Just my 2 Mini Cents
Old Nov 19, 2009 | 03:23 PM
  #115
pete v's Avatar
pete v
Finally found the time to install the MiniDoMore on Fubbsy. Took just over two hours and the hitch went on without a hitch.
Only one problem both screw heads in the rear wheel wells were stripped when I checked the. Dremeled off the edges of the heads leaving the center to slip through the wheel well holes.
Fubbsy's bare bottom:
Bikes loaded:
Old Nov 25, 2009 | 08:53 AM
  #116
jlloyd's Avatar
jlloyd
cheap trailer idea
I think my idea needs a little 'tweaking'. At higher speeds (70-80mph) it starts getting a little twitchy. Any ideas on how to remedy this problem?
Attached Thumbnails Mini Do More hitch install-cheap-trailer-1.jpg   Mini Do More hitch install-cheap-trailer-2.jpg
Old Nov 25, 2009 | 11:16 AM
  #117
taysan's Avatar
taysan
You need to weigh it down with a couple of your neighbor's kids.
Old Nov 25, 2009 | 11:18 AM
  #118
taysan's Avatar
taysan
Looks nice! Is that BRG? Same as mine - wondering if your windows are tinted and if so to what %? I'm thinking about doing mine, but wasn't sure how it would look with the silver roof. I like yours.
Old Nov 25, 2009 | 01:48 PM
  #119
pete v's Avatar
pete v
TAYSAN:
Sales receipt says:
35% on rear windows & doors
50% on front doors & sunroofs.
I did the lightest available tint on the front doors/sunroof for good visibility and the next darker on the rear windows for some privacy - but not total blackout.
No matter what percentage tint you have applied it will all screen out the same amount of UV/heat according to the installer.
HTH,
Old Apr 16, 2010 | 01:32 PM
  #120
Xeraux's Avatar
Xeraux
Just a heads up on the wiring package instructions.
On my 2010 Clubman S, we followed the provided instructions to the letter and unbeknownst to me, while all the lights work, it locked up my drivers-side rear barn door.
It's now cost me US$500.00+ to get the dealership to get the door opened.
Before you install the wiring package, make sure you know which wires to tap into regardless of what Mini Do More's instructions say.
Old Apr 18, 2010 | 09:50 AM
  #121
Brent@minidomore.com's Avatar
Xeraux
I am very surprised that you had a problem with the install. We have seent this once or twice but it has been due to taping the incorrect wire for the signal to the Modulite unit. Did you perform the install or did someone else?
We would really appreciate it if you would contact us directly with your problem and gave us an opportunity to work with you to correct the issue and identify the problem before you place a post like this on a public forum. If you look and ask around I think you will find that Mini Do More has a reputation for working with our customers issues directly and quickly.
What is your name and under what name did you order the wiring harness?
Old Apr 18, 2010 | 11:29 AM
  #122
Arthur's Avatar
Arthur
Any interest in the Philadelphia area to do a group install? We'll help each other. Always nice to have someone else, especially with mechanical common sense, on hand for moral support.
Old Apr 19, 2010 | 12:54 PM
  #123
TheMadDane's Avatar
TheMadDane
I had the same problem with the Wiring! I followed the instructions to the T.
Maybe different wiring for the 2009+?
The wire they have mentioned "Locked" my back door, I don't remember which one I ended up tapping into but it was NOT the one they described ( I think blue?).
Old Apr 21, 2010 | 09:59 AM
  #124
rexicon's Avatar
rexicon
Bikes loaded:
What bike rack is that?
Old May 7, 2010 | 06:44 AM
  #125
Arthur's Avatar
Arthur
A word of caution...wish I had seen the recent postings in the Coupe Talk forum re MiniDoMore being nonresponsive to calls and e-mails. I purchased the tow hitch online 4 days ago, sent Brent an e-mail yesterday and just left him a voicemail. I might just be a bit impatient and not giving Brent sufficient time to respond but I am getting the sinking feeling.
