R55 Daytime running lights - w Xenons
In my former 1st generations MINIs, I swear the programmable daytime running lights (also w/Xenons) were different from this Clubman's.
When I'm in the Clubman inside the garage and can see the way the headlights hit the wall in front of me, it appears that the running lights when switched to the full on Xenon headlights don't change brightness at all. Am I just imagining this or is this something new in the 2nd generation?
I just programmed my Clubman with Xenons this weekend to enable the daytime running lights when the car is running. The manual seemed to indicate that the running lights are the same as low beams, which would be consistent with what you're seeing.
Hey there - just curious on why you deactivated them? Is it due to the cost of replacing the Xenons after prolonged use, or? I may deactivate mine as well based on the feedback. Thanks
Aha, so I have not lost my mind.
I think that my insurance company gives a discount for daytime running lights - not that they will know if I have mine on or not... I am sorry that they are the low beams of the xenons because they are awfully bright to be used as running lights, or so it seems to me.
I've parked my Mini with the engine running and walked down the road a ways to see what the Xenon lights look like to oncoming traffic. They're fine - not too bright at all to my eye. My understanding is that HID headlamps can't be run at reduced voltage the way halogens can, so it's full strength or nothing.
That sounds the same as with the R56 Coupe. My understanding is that they are a constant brightness. The low beams are only different from the high beams by a mask that blocks the top of the beam. That's why the low beams have such a sharp cutoff.
I turned my DRL off. The expensive part about Xenons is that the igniter is stressed each time you fire them up. Otherwise, they are supposed to last a longtime. So, if you are running errands and doing a lot of short hops, you are firing the igniters frequently. I'll run the low beams in situations where I think it would improve visibility, such as the sun being behind me on a two lane road.
Interesting about the "igniters". Where did you learn about them? Depending upon how many ignitions are in the life time of a pair of xenons, you're right about not wanting them to fire up every time you take a quick trip...if that's one's driving style. Appreciate your post Robin.
In my R53 Mini, I inquired of my SA about a year ago if the daytime running lights were simply the low beams switched on all the time (Xenon). He said yes, so, taking his word for it, I didn't have them activated, and just turn on the parking lights out of habit now, adding the fog lights (which are pretty bright) if I think it's necessary and, of course, the low beams are always available if I feel the situation requires it as Robin pointed out.
Well, I guess the R50s were different. I miss turning on my headlights and watching them swivel up and level off. Oh well, I'll get used to it.
I am interested to learn more about that igniter deal with the xenons, though.
If anyone wants to learn more about lighting,
hidplanet.com/forums
and
www.danielsternlighting.com
are very helpful sites!
Personally i'm waiting to see what kind of projector I can cram into my stock foglight housing and doing a retrofit. I have several waiting in anticipation
and
Glad I found this thread! I turned on my DRL's yesterday thinking that just the top of my front fogs might light up. Imagine my surprise when then Xenons and all the parking lights came on instead
. I have since deactivated. I agree that having the Xenons come on every time you drive the car, will require them to be replaced prematurely. I like the idea of just turning on the parking lights when needed. Thanks as well to Robin about the tip when the sun is behind you. Great idea
Hi all,
There are MANY studies on how daytime driving lights improve safety and visibility of vehicles. It is for this reason that it is law in Canada to have them. Personally, I turn on the lights always, so that the rear lights come on as well. I find it very irriating when others do not, as I think it is MUCH easier to see them, so why not add whatever I can so others can see me in my smaller then normal car.
How much shorter are the bulbs going to burn out? My last Mini lasted 3 years with no issues, so are we talking the bulbs are going to burn out after 5.5 years instead of 5.6 or what? Personally, the extra safety is worth it to me!
SuperGreg, it looks like you have your fog lights on but the rest of your lights off in your sig. picture. Is that correct? If so, how did you do that? When I turn on my fog lights, all the lights come on.
That's my question too. How many hours can we expect to get out of the Xenons? If it's over 5,000 hours, then I guess it wouldn't make much of a difference. But if it was a lot lower than that, like 1,000 hours, than I'd be more inclined to leave them off.
. I have since deactivated. I agree that having the Xenons come on every time you drive the car, will require them to be replaced prematurely. I like the idea of just turning on the parking lights when needed. Thanks as well to Robin about the tip when the sun is behind you. Great idea And the Chrysler products that use the regular headlights for DRLs have this weird issue where one headlight will turn off if you use the blinker.
I wonder which states. Some auto manufacturers, like GM & Chrysler, have made the front park lights the DRLs. And then they blink when you use a blinker.
State DMV rules don't care what lights are on or off during the DAY, the rules are for nighttime, usually dusk to dawn, and they require that low-beam headlamps be on. Some states also require that low-beam headlamps be on if it's raining. Since many cars don't have the DRL feature at all, they're unregulated.
too bad the daytime running lights are not like they are on BMWs I see around town, where it seems just a ring around the lights are on. I think that looks pretty cool. I will probably use DRL because of insurance, but would prefer to be without them for aesthetic reasons.
I think those of you worried about burning out your igniters by running your HID lights all the time are unnecessarily concerned. My CayenneS is now over 4 years old and since new, I have been turning on the HID headlights every time I start it (daylight running lights not available) -- a lot of repeated starting/stopping over the years. No problems whatsoever with the HIDs. In the MINI I just keep the HID headlights switched on all the time, they come on when I start the car, off when I turn the ignition off.
